80stars
MN, USA Status: offline
Thanks Albert, I think I will do a build thread on this one, sort of a "throw back", there may be others out there looking at the same project. That way you and others with experience can help me better during the build with my questions. Albert you addressed this earlier in this thread that the kit is perfect as is, that making a modification to a mid wing will only be for my challenge as a builder, not performance to the aircraft. In your experience building this kit, can the mid wing mod be performed and sill allow room inside the fuse for equipment? My concern would be the fuel tank. In your aircraft did the tank sit on top of the wing tube? Forgive me, I have not yet looked at the plans for this kit, I'm not even sure it's a two piece wing with a tube. From other owners pictures it is hard to tell the design and layout of the airframe for me to make a decision if the mid wing mod is even feasable. Doug
