RE: 30% 300S mod to mid wing?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 30% 300S mod to mid wing?
Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: 30% 300S mod to mid wing? - 2/2/2008 2:11:23 PM
Neilbo4
Status: offline
albert, I know you sent me a pm earlier but any news on the plane from your friend?
(in reply to 80stars)
       Post #: 51
RE: 30% 300S mod to mid wing? - 2/2/2008 11:49:18 PM
80stars
Status: offline
quote:
ORIGINAL: zzw26n
Great job Doug .......... looking real good!
Thanks Ward,
It's been a good choice to build, there are so many things I will be looking for when I get a chance to build a 40%er.
After thinking through the lay out for a single canopy and forward hatch assembly and matching it with the turtle deck I am using Albert's advice. I am scraping the cockpit foor F4A with exception of how it flushes out the clam shell sides. I will build a frame for the canopy that will include the forward hatch like the newer design on a 40%. I added a piece of 1/4 stringer to the bottom of F3A and the cut out from F4A between F2A and F5A to strengthen the seam and also to give me a better surface to attach the clam shell side. I added some lightening holes to F3A and F4A.
My next move is to sheet the turtle deck so I can finish the truss back to the tail and have the proper width. After that I will add the remaing 1/4" stringers and build the clam shell sides. That way the canopy frame assembly can be build to match exactly for length and width to the fuse sides.
Doug
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to zzw26n)
       Post #: 52
RE: 30% 300S mod to mid wing? - 2/3/2008 7:33:25 PM
80stars
Status: offline
I thought it would be fun to set it up on the gear and check the layout of the front hatch, canopy and rear deck. It was also a little confidence boost to feel like was begining to look like an airplane. I am sheeting only the bottom edges of the hatch and rear deck, and to save some additional weight will hot wire out some of the foam core.
I am kind of at a stand still till the glue dries on the hatch and deck cores. I think I will cut and edge glue the sheeting for the horizontal and verticle stabs. This will be a challenge because half of the stack of sheeting is not edge trued with a BIG bow through the center.
Doug
Thanks Ron for the vote of confidence, I look forward to bringing it to the field.
Click for fullsize
Click for fullsize
       Post #: 53
RE: 30% 300S mod to mid wing? - 2/3/2008 7:35:21 PM
80stars
Status: offline
A couple more for those of us who like pictures.
Click for fullsize
Click for fullsize
       Post #: 54
RE: 30% 300S mod to mid wing? - 2/4/2008 5:37:03 PM
80stars
Status: offline
After sheeting the rear deck and forward hatch and then laying everything out on the plans, I was very unhappy with the fit of the forward hatch to the fuse sides. The forward hatch overhangs both sides of the fuse by nearly a 1/4" equally on both sides, which when you account tor the 3/32 clam shell sideing = aprox 3/32ish too much overhang. I have checked the plans to ensure I had not built or cut down anything by accident, all looks good. With out a hollowed out front hatch to I can not pull the sides in to match. My solution was to cut two 10mm wide strips of 3/32" balsa and laminate it to the sides of F4A and F3A and the 3/8" stringer I added earlier, between F2A and F5A. With a long sanding bar I will then take that 3/32" strip down to the exact width I need for the front hatch and taper it to match at F5A. Just call me Mr Balsa Dust.
Doug
Click for fullsize
Click for fullsize
       Post #: 55
RE: 30% 300S mod to mid wing? - 2/4/2008 5:54:12 PM
zzw26n
Status: offline
Doug,
Your going to end up with a nice Plane! I have a DA-50 I'll sell you, PM me.
Ward
       Post #: 56
RE: 30% 300S mod to mid wing? - 2/4/2008 6:39:19 PM
80stars
Status: offline
quote:
ORIGINAL: 80stars
Doug
(SP) vertical stab
       Post #: 57
RE: 30% 300S mod to mid wing? - 2/6/2008 2:33:41 AM
80stars
Status: offline
I attached the rear deck last night and finished the cross trussing today. I am begining to lay out the wings and will begin the sheeting process next. Any recommendations for a ratio when lengthing and tapering ailerons, or do you just do what looks good? The plans call for a 33" non-tapered 3.25" aileron on a 42" wing panel. I layed out a length of 38.5 and a taper from 3.25 at the tip to 4.75 at the root, looks good .
Doug
Click for fullsize
Click for fullsize
       Post #: 58
RE: 30% 300S mod to mid wing? - 2/9/2008 5:23:39 AM
80stars
Status: offline
Ahhh...
The wing task at hand. Nothing like the smell of polystyrene foam cores in the morning. After laying out the ailerons, I pluged the tube, fit the stress sockets, 1/4" drilled the tube slot (for glue), and glued in the phenolic tubes. While thinking through the layout for my aileron servos I made my wing sheets from the 1/16x3.25x42.5 balsa sheeting. I am going to blame the irregular (bowed) edging of the balsa to age and storage of the kit. The edges may have been trued 14 years ago, but not today. I did my best to pull the edges together, but I still had more glue seep through the joints than I would have liked. Most of it sanded flat on the work top with the palm sander using 220 and 400 grit, I am hopeful that after I get the sheets on the foam cores I will be able to work any remaing glue into a blend.
Click for fullsize
Click for fullsize
       Post #: 59
RE: 30% 300S mod to mid wing? - 2/9/2008 5:25:30 AM
80stars
Status: offline
One of four wing sheets and the aileron template.
Click for fullsize
Click for fullsize
       Post #: 60
RE: 30% 300S mod to mid wing? - 2/9/2008 5:29:34 AM
80stars
Status: offline
Cut out for aileron and servo wire.
Thanks Albert for the router attachment on Dremel idea, it does work great.
Thanks to, ? someone for the hot wire on my soldering iron idea for the servo wire cut out.
Doug
Click for fullsize
Click for fullsize
       Post #: 61
RE: 30% 300S mod to mid wing? - 2/9/2008 5:34:44 AM
80stars
Status: offline
Servo cutouts complete, and servo channel capped with 1/4" balsa (thanks again Albert).
260lbs on each wing core, bench is holding 520lbs no problems, no deflection.
Doug
Click for fullsize
Click for fullsize
       Post #: 62
RE: 30% 300S mod to mid wing? - 2/9/2008 5:44:22 AM
80stars
