Campgems
CA, USA Status: online
Huge box arived tonight. Just took a quick peek and there isn't much wood there. A look at the plans confurmed that. It is an interesting build concept. Basicly a strong square tube with the details attached. The tail is going to be the only building really. Looks like a lot of painting vs covering though. The landing gear looks good. I think I'll beef up it's mount though. The split elevators with two servos are going to make me think a bit. I have one plane with them, and it isn't a problem with the radio, I'm just not sure I really need them. Have to think it over. Looking at this guy, it isn't as big as my 4*60. Same wing span, but a shorter fuselage. That coupled with the split wings is going to make trips to the field a lot easier. On the topic of size, any recomendations for servo size. I fly the 4*60 with Futaba 3151 digitals. This guy looks as if they, the 3151's, would be enough. I've got bigger ones in hand, if needed. For right now, I think I'll do this, 2 3151's for elevator and 2 for ailerons. Then one of the 9003's in a pull pull for the rudder. Mini servo for the throttle. Carbon fiber pushrods for the elevator. Those who have built one, how does the cowl hold up, should I look at a Fiberglass specialities on in the future? Same for the wheel pants. Don
