Rear shock leaking    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Rear shock leaking
Page: [1]
Login
Rear shock leaking - 1/9/2008 10:36 PM
zeen420
Score: 100
Last Login: 7/4/2008
Status: offline
Well only prob so far with new buggy is the rear shock is leaking, whats the best way to fix this? should i just take em apart and put em abck together?
Hide Signatures
       Post #: 1
RE: Rear shock leaking - 1/9/2008 10:50 PM
Macanan
Score: 100
Last Login: 4/10/2011
Status: offline
Are they the stock shocks ?
_____________________________
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
(in reply to zeen420)
       Post #: 2
RE: Rear shock leaking - 1/9/2008 11:08 PM
willashcroft
Score: 100
Last Login: 1/25/2009
Status: offline
buy some new 'uns. they arent that much lol
Old-Skool Traxxas SportMaxx. :P
Hide Signatures
(in reply to Macanan)
       Post #: 3
RE: Rear shock leaking - 1/9/2008 11:15 PM
zeen420
Score: 100
Status: offline
Ya, stock ones, id rather not buy new ones considering these are brand new.
Hide Signatures
(in reply to willashcroft)
       Post #: 4
RE: Rear shock leaking - 1/9/2008 11:27 PM
Macanan
Score: 100
Status: offline
Where they leaking from ? the top or bottom. If there leaking form the bottom and not much at all there will be some oil from where the rod goes in and out of it, if its leaking from the top which I had that prob once they come apart on me, what I did is filled it with 10W-40 motor oil and screwed them back together, thats about all you can do.
Hide Signatures
       Post #: 5
RE: Rear shock leaking - 1/9/2008 11:34 PM
5lagd
Score: 100
Last Login: 5/22/2013
Status: offline
how full do you fill the shocks with oil? i bought some traxxas shocks and modifying them to fit (it's gonna work!!!!!!!!!!) on my 1/10 buggy. i need to know how full to fill.
< Message edited by ldgasp -- 1/9/2008 11:35 PM >
Stampede 4x4 & Atomik Barbwire.
Hide Signatures
       Post #: 6
RE: Rear shock leaking - 1/9/2008 11:35 PM
zeen420
Score: 100
Status: offline
its leaking from the bottom part, but not alot.. and just noticed that the front one is leaking from the bottom to..
Hide Signatures
       Post #: 7
RE: Rear shock leaking - 1/9/2008 11:42 PM
Macanan
Score: 100
Status: offline
I had a front shock snap on me one time, the first 2 hours I had it after breakin, I was doing some jumping from a ramp, well needless to say I hit the ramp to the side of it and we had a picnic table close the the ramp, well my buggy at the time slammed right into the leg of the table and snapped the rod going into the shock right in two, here's pictures of it when I did it and fixed the broken shock by rigging it up till I got new ones in. How I fixed my shock and rod while waiting on new parts
First off you have to find a bolt small enough to fit inside of the shock with 2 nuts that fit it, one with threads to the bottom of the bolt, second drill a hole in a penny if you dont have the right washer, third find a small piece of metal to bend in half and drill 1 hole in each bend, fourth take apart the shock and drill a hole to the size of your bolt in the bottom of your canister, insert bolt into shock canister threaded part first, put your shock back together, then you put the spring back onto the shock, holding back the spring, screw on one nut then put the penny on it, then put your angled piece of metal that you have drilled and cut on it, then the other nut, and adjust tension with the nuts and tighten them.
This is how we southern boys fix things
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Macanan -- 1/9/2008 11:44 PM >
Hide Signatures
       Post #: 8
RE: Rear shock leaking - 1/9/2008 11:44 PM
twomanytoys
Score: 100
Last Login: 4/23/2009
Status: offline
The stock plastic shocks will leak no matter what.
The one with the most toys wins. I think I may have a good chance of winning.
Hide Signatures
       Post #: 9
RE: Rear shock leaking - 1/9/2008 11:58 PM
zeen420
Score: 100
Status: offline
mine are not the plastic ones..here,
Click for fullsize
Hide Signatures
(in reply to twomanytoys)
       Post #: 10
RE: Rear shock leaking - 1/10/2008 12:04 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: zeen420
new o rings
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 11
RE: Rear shock leaking - 1/10/2008 12:06 AM
zeen420
Score: 100
Status: offline
quote:
ORIGINAL: ehroof
quote:
ORIGINAL: zeen420
new o rings
really? well if it means im going to have to buy something to fix them with i might aswell just get some ones, just kinda sucks seeing how i haven't even broke it in yet
Hide Signatures
(in reply to ehroof)
       Post #: 12
RE: Rear shock leaking - 1/10/2008 12:33 AM
Macanan
Score: 100
Status: offline
On the aluminum ones what I did to mine is add BLUE Lock tight but, be careful and not get any on the inside of the shock or it will lock them up, refill with oil before you add the lock tight.
Hide Signatures
       Post #: 13
RE: Rear shock leaking - 1/10/2008 12:52 AM
zeen420
Score: 100
Status: offline
quote:
ORIGINAL: Macanan
Ah ok, was thinking about that but wasn't sure, i just got some blue locktite too... so just put it on the top and bottom threds of the shock?
Hide Signatures
       Post #: 14
RE: Rear shock leaking - 1/10/2008 1:05 AM
Macanan
Score: 100
Status: offline
Yup thats what I did and it holds well
Hide Signatures
       Post #: 15
RE: Rear shock leaking - 1/10/2008 1:24 AM
zeen420
Score: 100
Status: offline
Great, thanks for the help all!
Hide Signatures
       Post #: 16
RE: Rear shock leaking - 1/10/2008 2:12 AM
5lagd
Score: 100
Status: offline
i found some traxxas shocks and used the to replace the stock ones http://www.rcuniverse.com/forum/m_6877602/tm.htm bottom of the page
Hide Signatures
       Post #: 17
RE: Rear shock leaking - 1/10/2008 2:19 AM
zeen420
Score: 100
Status: offline
those are cool, was looking at the HPI MT2 ones also.. Ok heres a stupid question! how do you make those little pull tab things for the body clips?? LOL, i can see from some pics that there obviously zip ties and fuel lines.
Hide Signatures
(in reply to 5lagd)
       Post #: 18
RE: Rear shock leaking - 1/10/2008 2:21 AM
webbl19
Score: 100
Last Login: 9/4/2009
Status: offline
it looks like a zip tie with fuel tubing around it. i could be wrong.
Exceed Razor, RedCat Tsumani and wanna be Volcano
Hide Signatures
       Post #: 19
RE: Rear shock leaking - 1/10/2008 2:36 AM
5lagd
Score: 100
Status: offline
cut a piece of fuel line around 3/4-1" take a small ziz tie and zip it closed and fold it over about 3/8-1/4" long. slide the zip tie thru the fuel line and then attach a body clip. and they are done.
Click for fullsize
< Message edited by ldgasp -- 1/10/2008 2:40 AM >
Hide Signatures
(in reply to webbl19)
       Post #: 20
RE: Rear shock leaking - 1/10/2008 4:17 AM
zeen420
Score: 100
Status: offline
ahh i see now, thanks man!
Hide Signatures
(in reply to 5lagd)
       Post #: 21
RE: Rear shock leaking - 1/10/2008 4:21 AM
ehroof
Score: 105
Status: offline
o rings cost like $1 for a bunch of them
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.469RCU1
