RE: WOW CHEAP A123 packs for mini's!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: WOW CHEAP A123 packs for mini's!
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: WOW CHEAP A123 packs for mini's! - 1/16/2008 2:41:00 AM
Mr. Mugen
Status: offline
I am updating my thunder power 1010C charger to charge A123's. These cells are not available to the public from A123 just big companies like B&D. My lhs guy is making a charger for us to try and see if it works using the existing A123 charger for thier 2300's (actually 2200's). I kind of got the jist of what he is doing but wont post about it until it is proven.
Kevin
_____________________________
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
(in reply to banzaij)
       Post #: 26
RE: WOW CHEAP A123 packs for mini's! - 1/16/2008 3:18:45 AM
siameez
Status: offline
Here's a good intro to A123 batteries:
http://www.slkelectronics.com/DeWalt/index.htm
And here's a great charger from FMA that does A123 too:
http://www.fmadirect.com/products.htm?cat=45&nid=4
http://www.fmadirect.com/index.htm
       Post #: 27
RE: WOW CHEAP A123 packs for mini's! - 1/16/2008 8:58:30 PM
Deftones123
Status: offline
the batteries in the vpx can you exactly make a battery pack out of it and charge it on the charger the vpx batteries came with?
       Post #: 28
RE: WOW CHEAP A123 packs for mini's! - 1/16/2008 10:35:55 PM
Beomagi
Status: offline
The original a-123 on a mini (9.9v, quark 66A hiding the third battery). This pushed the ammo 3200kv 666watt motor on a 31t pinion.
Great to hear that mini a123 batteries are finally available!
Characteristics - 3.3v nominal. 60c peak, 30c constant discharge.
cutoff is needed, but it can be easily seen, as the discharge is near constant, then drops like a ton of bricks.
I use an eos 5i for them. Atm, that pack is powering my dremel (modded to run off rc packs instead of measly 700mAh packs...)
< Message edited by Beomagi -- 1/16/2008 10:41:17 PM >
(in reply to Deftones123)
       Post #: 29
RE: WOW CHEAP A123 packs for mini's! - 1/17/2008 3:54:01 AM
rc-junky007
Status: offline
i took apart a camcorer battery and had 2 cells like this and they say 7.2v 5.0wh and i dont know what 5.0wh meand and is that the capacity or what
(in reply to Beomagi)
       Post #: 30
RE: WOW CHEAP A123 packs for mini's! - 1/17/2008 5:01:31 AM
kent_man
Status: offline
Wh is watt hours. Watts = Amperage x Voltage so it's about 694mAh. What are you planning on using the battery for? I doubt it will work for anything RC because it won't be able to discharge quick enough for anything high current, unless you are using is as a rx pack.
Savage X 4.6, RC18T Factory Team Kit with 6800 mamba, RC18R Niteline
(in reply to rc-junky007)
       Post #: 31
RE: WOW CHEAP A123 packs for mini's! - 1/19/2008 12:55:57 AM
rc-junky007
Status: offline
i was gonna use it in my rc18t but i thought it would have a low discharge rate like you said so i dont know
(in reply to kent_man)
       Post #: 32
RE: WOW CHEAP A123 packs for mini's! - 1/19/2008 1:58:55 AM
Frozen72
Status: online
Mr.Mugen does that battery fit in the Detta ST?
"My friends don''t know I''m black"
Rap - Lies = Hip-Hop
       Post #: 33
RE: WOW CHEAP A123 packs for mini's! - 1/19/2008 2:16:46 AM
Mr. Mugen
Status: offline
Yes it does....with lots of room to spare.
(in reply to Frozen72)
       Post #: 34
RE: WOW CHEAP A123 packs for mini's! - 1/19/2008 3:26:40 AM
maybelater29
Status: offline
quote:
ORIGINAL: Mr. Mugen
How are these batteries working for you?
Tek18 / M18MT / TC5 / B44
pittsburgh1_18racing.com
(in reply to Mr. Mugen)
       Post #: 35
RE: WOW CHEAP A123 packs for mini's! - 1/19/2008 4:03:50 AM
Mr. Mugen
Status: offline
I ran one pack for 2 charges so far. Waiting for my usb cable to come in for the 1010C. Once it gets here I will run them hard.
Kevin
(in reply to maybelater29)
       Post #: 36
RE: WOW CHEAP A123 packs for mini's! - 4/5/2008 10:36:24 AM
lolbbq
Status: offline
old thread i know but...any updates?
XTM Rage/Tamiya TL-01/Wind Hobby Ferret(2)/Losi Micro DT(3)
       Post #: 37
RE: WOW CHEAP A123 packs for mini's! - 4/5/2008 5:37:35 PM
Mr. Mugen
Status: offline
Yes! They are awesome! I use my 1010C to charge them now. I ran them in mini-t's, detta's, rc18's, m18t, KMI's...and planes so far. They are the best batteries I ran to date. I ordered another charger so I can charge a couple of packs at once. This time I got the 610C. Both are nice chargers.
Kevin
(in reply to lolbbq)
       Post #: 38
RE: WOW CHEAP A123 packs for mini's! - 4/5/2008 5:53:28 PM
Mini_Me
Status: offline
I love my 610C. How are you fitting them in the m18t? Your measurements would indicate the pack is 38mm wide, and I have had problems fitting anything wider than 34mms.
M18/T FAQ available on http://www.teamxray.com/
       Post #: 39
RE: WOW CHEAP A123 packs for mini's! - 4/5/2008 6:15:47 PM
Mr. Mugen
