Beomagi
Joined: 1/3/2006 From: Bayonne, NJ, USA Status: offline
The original a-123 on a mini (9.9v, quark 66A hiding the third battery). This pushed the ammo 3200kv 666watt motor on a 31t pinion. Great to hear that mini a123 batteries are finally available! Characteristics - 3.3v nominal. 60c peak, 30c constant discharge. cutoff is needed, but it can be easily seen, as the discharge is near constant, then drops like a ton of bricks. I use an eos 5i for them. Atm, that pack is powering my dremel (modded to run off rc packs instead of measly 700mAh packs...)
< Message edited by Beomagi -- 1/16/2008 10:41:17 PM >
