RE: WOW CHEAP A123 packs for mini's!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: WOW CHEAP A123 packs for mini's!
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 2:38:52 AM
TheTruckingGuru
Status: offline
What connector did you solder on your home made pack to charge it with? Also what about balancing the packs?
(in reply to Deftones123)
       Post #: 51
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 3:46:57 AM
Mini_Me
Status: offline
Im really interested in knowing (pictures)! If it can fit nicely in my M18T Pro, I might forego getting Flightpowers. Sides, I wanna try out new tech! With a 60000kv and the slightly lower voltage these put out, I think it might make a perfect vehicle.
_____________________________
M18/T FAQ available on http://www.teamxray.com/
(in reply to TheTruckingGuru)
       Post #: 52
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 4:09:19 AM
lolbbq
Status: offline
Deftones123, could you snap some pics of the pack? On and off the vehicle if you could.
XTM Rage/Tamiya TL-01/Wind Hobby Ferret(2)/Losi Micro DT(3)
       Post #: 53
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 2:41:14 PM
Deftones123
Status: offline
the pack looks exaclty like the picture on page one of this thread, im soldered on a deans plug, and I never have balanced out my packs, all im using is a 2 hour nimh wall charger to charge mine, people said its not good, but I have about 50 charges on my I just cut it out at the correct voltage and mah, and its been fine
(in reply to lolbbq)
       Post #: 54
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 3:57:35 PM
Mr. Mugen
Status: offline
Def- your probably going to be ok with that set up. A guy at our local track does the same thing with good results.
I do not balance mine yet either. My lhs just called me friday with some news on balancing. I will meet with him this coming week for my lesson. When I am better informed I will let you's know. He sounded like this was an easy thing to do so I will see. I am making a 30 cell pack out of these for a fast plane project. Actually going to be a 10s3p. That is 10 cells in series and 3 in parallel.
Kevin
P.S. I just bought a new charger that also supports these cells. It is the thunder power 610C. I will charge up to 6 cells lipo/A123. Check it out. It is a nice charger for the money.
< Message edited by Mr. Mugen -- 4/6/2008 4:01:30 PM >
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
       Post #: 55
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 4:15:09 PM
Deftones123
Status: offline
so is the life of the batterys actually shorter if I charge them the way Im doing, I mean im on 50 even if I get 100 runs out of the pack thats fine by me
(in reply to Mr. Mugen)
       Post #: 56
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 4:37:47 PM
Frozen72
Status: offline
Are these the batteries that can be charged at 2C? So it I got the 1100 mah pack I could charge it at 2 amps.
"My friends don''t know I''m black"
Rap - Lies = Hip-Hop
       Post #: 57
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 4:41:54 PM
Mr. Mugen
Status: offline
You can charge these at 5amps safely.
Def- Your one of the pioneers of this....let us know what happens. I cannot answer that question......unsure. Can you measure how many mah are going out?
(in reply to Frozen72)
       Post #: 58
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 4:48:32 PM
Frozen72
Status: offline
Mr.Mugen how long were the runtimes in your Detta ST? If I charged at 4 amps it would be fully charged in about 15 min. correct.
       Post #: 59
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 5:28:20 PM
Mr. Mugen
Status: offline
I never timed them. I would say about the same as any other 1100mah pack.
       Post #: 60
RE: WOW CHEAP A123 packs for mini's! - 4/6/2008 8:12:03 PM
Deftones123
Status: offline
ill keep you guys posted
       Post #: 61
RE: WOW CHEAP A123 packs for mini's! - 4/7/2008 12:02:15 AM
Mr. Mugen
Status: offline
Nothing really specail about putting them in. You could take a piece of foam and glue it along side of the battery so I wont slide out on impact. I ran mine on and oval in a gym and didnt have any problems with it coming out. However I think if I was jumping and turning right then maybe I would want it. I may put a piece in it now just to be safe.
Click to see fullsize image.
Click for fullsize
(in reply to Mini_Me)
       Post #: 62
RE: WOW CHEAP A123 packs for mini's! - 4/7/2008 4:20:35 AM
Mini_Me
Status: offline
Thanks Mr. Mugen! How is the pack being retained on the outside? I measured and the distance is like 35mm between the pegs... Did you wittle them down some or are you relying on the top clamp to keep it from shifting?
       Post #: 63
RE: WOW CHEAP A123 packs for mini's! - 4/7/2008 1:08:36 PM
Deftones123
Status: offline
sych a good pack for the price
       Post #: 64
RE: WOW CHEAP A123 packs for mini's! - 4/7/2008 1:30:02 PM
Mr. Mugen
Status: offline
Read what I wrote? Above pic.
Kevin
