RE: WOW CHEAP A123 packs for mini's!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: WOW CHEAP A123 packs for mini's! Page: <<   < prev  1 2 3 4 [5] 6 7 8 9 10   next >   >>
Login
RE: WOW CHEAP A123 packs for mini's! - 4/25/2008 3:59:58 PM
Acs_guitars
Status: offline
I have never had, nor seen a lipo burn up in person, only videos online of people shorting them out to show what can happen. I have flown airplanes using LiPo batteries for a few years now and have seen quite a few planes using them crash with no explosive results. I am not saying the A123 packs are bad at all. I just have a dozen or so lipos that fit my mini and plan to use those... If I saw any REAL advantage to using A123 packs, I would. Reasons that you state are not good enough for me. I can take faster charge times and higher burst ratings as TRUE advantages... Not simply saying that they are tolerant to irresponsible charging. I take care of my batteries and have nice chargers meant for LiPo's that don't overcharge the packs I don't put myself at risk by being so careless. I have also never popped a nicad or nimh pack by overcharging, nor puffed a lipo... years and years in this hobby and I have never had a battery fail because of my charging them, only dead cells due to thier known lifespan. If you don't want a lipo to burn, you simply don't short-out or overcharge the pack - Not hard things to do (use responsibly and as intended).
- Thank you Mr. Mugen for pointing out REAL advantages of these A123 packs, I will certainly plan on trying these out in the future.
< Message edited by Acs_guitars -- 4/25/2008 4:33:45 PM >
_____________________________
Originator of the Web Crawlers Association WCA# 0001
AMA # 880471
(in reply to Deftones123)
       Post #: 101
RE: WOW CHEAP A123 packs for mini's! - 4/25/2008 4:10:22 PM
Mr. Mugen
Status: offline
Some people dont know what "C" ratings are and overdraw their lipo's as well. This ruins them. I had a few eye openers this way. Since then I do all math first. And use a watts up meter to test all draw before applying them.
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
(in reply to Acs_guitars)
       Post #: 102
RE: WOW CHEAP A123 packs for mini's! - 4/26/2008 10:49:19 PM
Frozen72
Status: online
Do these fit in the Mini-T chassis.
"My friends don''t know I''m black"
Rap - Lies = Hip-Hop
(in reply to Mr. Mugen)
       Post #: 103
RE: WOW CHEAP A123 packs for mini's! - 4/26/2008 10:55:39 PM
Metallover
Status: offline
They should fit a mini T, two cells side by side are equal to 4 2/3a size cells, which is what the mini T uses. Im not saying to do it and it will work for sure - they might be just a little bit taller.. mr. mugen would know.
I went to menards today and most of the black and decker stuff including these batteries were on sale for i think 16.99 or 15.99, but Im guessing the sale will probably end tomorrow.
Dimebag Darrel 1966-2004 RIP
If the mamba 8000kv is overkill...
(in reply to Frozen72)
       Post #: 104
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 12:10:00 AM
Frozen72
Status: online
Who every was charging the battery with a Ni-Mh charger are they still going strong?
(in reply to Metallover)
       Post #: 105
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 2:10:28 AM
Deftones123
Status: offline
I charge mine with a nimh wall charger, I have over 70 charges on one of the packs and its going strong, and it barely fits in the mini t chassis, im running the 2 cell vpx packs in my mini-t and it rips amazing pack
       Post #: 106
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 2:13:00 AM
Metallover
Status: offline
you could run a 3s pack in a mini t...
If anyone still needs a reason to buy these cells, look at this. http://youtube.com/watch?v=A9ayuFBDrSg Its just a little durability test.
< Message edited by Metallover -- 4/27/2008 2:15:55 AM >
       Post #: 107
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 4:30:09 AM
Frozen72
Status: online
I'm not worried about my packs exploding just how cheap they are.
       Post #: 108
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 3:32:54 PM
The_Shark
Status: offline
hey i know im kinda stealing the thread for a sec, but...
1 can i use a 2s 10C 7.4v lipo for a brp with a standard servo and a 16D motor?
and will a normal radio shack 8cell 9.6 1000mah niCD work for this setup? the esc can handle 9.6.
thanks, when i have money, lith ion is the first upgrade.
HEY! if you dont want to be judged, dont make a spectacle of yourself!!
       Post #: 109
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 3:42:05 PM
Mr. Mugen
Status: offline
You should be able to. Remember the LVC. Depending on the esc your planning to use you may not have one (most likely not). You do not want to run your lipo below 6v if possible. How many mah is your 2s lipo?
(in reply to The_Shark)
       Post #: 110
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 4:14:16 PM
alloutcustom
Status: online
Will my triton charge these? i know there 3.3V but i dont know if it will. Im goo dwith all other batts, just dont know much about these.
If the boat doesnt fly, dont buy!!! ; )
       Post #: 111
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 4:47:34 PM
Metallover
Status: offline
I dont know about the triton, but I think I found a pretty good a123 charger.
http://www.sussex-model-centre.co.uk/shopexd.asp?id=23944
It is 60.00 usd. Does anybody know anything about this charger? This may push me into buying a123s for my savage
(in reply to alloutcustom)
       Post #: 112
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 4:59:20 PM
rschoi_75
Status: offline
I don't think the triton is able to charge A123 cells. The specs from tower do not mention anything about LifePO4 (a123) capabilities.
Of course I''ll have coffee... I always have coffee when I''m watching radar. Everyone knows that!
       Post #: 113
RE: WOW CHEAP A123 packs for mini's! - 4/27/2008 6:23:54 PM
Acs_guitars
Status: offline
The Triton 2 has the option to charge LiIon cells. But not the original Triton.
AMA # 880471
(in reply to rschoi_75)
