RE: PAU 36% Edge 540 Assembly
Tower Hobbies
Logged in as Guest
  Printable Version
C-130 Hercules 108" span Gas or Electric! - Kit
Seller:  penceaviation
Details:   $245.00   |  8/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: PAU 36% Edge 540 Assembly
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: PAU 36% Edge 540 Assembly - 1/27/2008 5:58:32 AM
flyinrazrback
Status: offline
Thanks for the info, without cutting the cowl ring I could not see any way to get the cowling on with the mufflers on. Shooting for a maiden next weekend.
_____________________________
"You'll get your chance smart guy!"
(in reply to islandflyer)
       Post #: 76
RE: PAU 36% Edge 540 Assembly - 1/27/2008 7:36:05 PM
islandflyer
Status: offline
Hi Everyone,
Thanks to Ken's hard work, the 36% Edge manual has been posted on the PAU web site, and is ready for download.
We will continued to support this thread with answers to questions, and new pictures and/or videos when we can get them.
< Message edited by islandflyer -- 1/27/2008 7:39:12 PM >
Herve Lejeune
PAU
(in reply to flyinrazrback)
       Post #: 77
RE: PAU 36% Edge 540 Assembly - 1/27/2008 8:10:59 PM
JohnVH
Status: offline
< Message edited by JohnVH -- 1/27/2008 8:13:21 PM >
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 78
RE: PAU 36% Edge 540 Assembly - 1/27/2008 8:28:11 PM
Grotesquebass
Status: offline
that build looks very straightforward doesnt look like any guesswork involved....now i am thinking this is gonna be my 35% do u guys have a good stock of them? Awsome pictures to love the look of an edge 540 in a harrier..
< Message edited by Grotesquebass -- 1/27/2008 9:33:14 PM >
"I've got a fever and the only prescription is more cowbell"
(in reply to JohnVH)
       Post #: 79
RE: PAU 36% Edge 540 Assembly - 1/27/2008 11:58:28 PM
Ken-h
Status: offline
Yes, very, "CS" the caveman series...lol. Of course this caveman did not get the header drop right. John takes does take sweet pictures.
Ken
Performance Aircraft Unlimited (PAU)
(in reply to Grotesquebass)
       Post #: 80
RE: PAU 36% Edge 540 Assembly - 1/28/2008 1:10:32 AM
Grotesquebass
Status: offline
< Message edited by Grotesquebass -- 1/28/2008 4:18:49 AM >
(in reply to Ken-h)
       Post #: 81
RE: PAU 36% Edge 540 Assembly - 1/30/2008 2:12:07 AM
Ken-h
Status: offline
Part 2 of the DA-85 install. The header is now finally installed and I needed to cut about a 1/2" off of it. Although not necessary, I also cut out some of the firewall to make access to the carb a little easier. Trimmed the cowling as shown and it still needs a little touching up, but its pretty much done. All in all, it still looks pretty clean even with the 85.
Ken
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 82
RE: PAU 36% Edge 540 Assembly - 1/30/2008 6:43:30 PM
ciressarg
Status: offline
I did my pre balance last night. I was very pleased to have the batteries under the wing tube. I thought for sure I would need them in the nose. They must be coming out a little nose heavy with the 100's? Seems like the 85 is a perfect fit for this airframe. I put a manual choke on mine, it was kind of a pain. I needed to extend the choke arm to make it work. Also what is up with the 3-48 threads in the throttle arm? Can you even buy a ball joint with a hole that size? I ended up drilling a 2-56 ball out to fit. I had to make a trip to the hardware store just for a a single screw and nut. Oh well b@%ch b@%ch b@%ch. I'm still on track for a maiden Saturday, weather permitting. I've been to busy working on it to take any pictures, I'll try to take some tonight. The install looks very clean with the absence of regulators. Also my engine mount and tunnel mod. look pretty cool.
Eric
(in reply to Ken-h)
       Post #: 83
RE: PAU 36% Edge 540 Assembly - 1/30/2008 7:16:51 PM
JohnVH
Status: offline
sounds like a good balance to me eric, Im sure the plane was designed around a 100, but will work well with an 85
(in reply to ciressarg)
       Post #: 84
RE: PAU 36% Edge 540 Assembly - 1/31/2008 3:18:18 PM
Ken-h
Status: offline
quote:
ORIGINAL: ciressarg
Eric
Eric,
That’s odd, my throttle was fine with 2/56 for both the 85 and 100. Do you have an earlier version of the 85? I am also interested in your throttle setup. I know how I am going to go about it, would like to see yours first. I may change my mind.
Ken
       Post #: 85
RE: PAU 36% Edge 540 Assembly - 1/31/2008 5:21:40 PM
sweetpea01
Status: offline
Ken--finish her up already......
www.propnuts.org
www.hobbiesxtreme.com
(in reply to Ken-h)
       Post #: 86
RE: PAU 36% Edge 540 Assembly - 1/31/2008 9:06:37 PM
ciressarg
Status: offline
It turns out it's a 2-56 just a bit sloppy. I was using a metric screw by mistake it threaded in perfectly, but wouldn't go through the ball. I brought my camera to work today, but I forgot my USB. I'll snap a picture of my servo mount when I get home and post it with the rest.
Eric
(in reply to sweetpea01)
       Post #: 87
RE: PAU 36% Edge 540 Assembly - 2/1/2008 12:29:25 AM
Ken-h
Status: offline
Eric,
Ahhh...that would explain it.
Ken
       Post #: 88
RE: PAU 36% Edge 540 Assembly - 2/1/2008 1:03:20 AM
yarom
Status: offline
What's up with the wood standoff? You could have used aluminum standoffs and saved some weight... Or do you like the sanding part...?
quote:
ORIGINAL: Ken-h
Ken
(in reply to Ken-h)
