j.m.
NC, USA Status: offline
i would suggest you use some of the construction techniques used on DLG's (discuss launch gliders) Instead of getting the wing to be 16 ounces, they get their whole craft under 16. Try taking a foam wing with a single carbon spar that is visible on both the top and bottom of the wing, and then coat this in a single layer of fiber glass. It will be much stronger and lighter than you think. To loose even more weight, you can then melt out the foam from inside it with acetone. (if wont hurt the fiberglass at all.) Then finally sand the fiberglass to make it smooth, and don't even bother with covering it. Here's an example of a DLG: http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6214 If you use really thin fiberglass, then you can do a couple of layers. Remember, go light on the epoxy. If you need to, yiu can warm your epoxy in your hands to make it more viscous.
_____________________________
!Signature your in it put, this read to time the took you If If the World didn''t suck, then we would just fall off.
