RE: Byron Corsair Build
Tower Hobbies
Logged in as Guest
Users viewing this topic: Cleco
    Search This Thread
Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  2/18/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Byron Corsair Build
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Byron Corsair Build - 1/26/2008 4:05 AM
Canuck1
Score: 100
Last Login: 3/20/2010
Status: offline
I took the wings out of the shucks, trimed back the balsa to the foam and sanded it smooth. Next I will add the balsa leading and trailing edges.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Eat, Sleep, Fly
Hide Signatures
(in reply to Peter_OZ)
       Post #: 51
RE: Byron Corsair Build - 1/26/2008 6:17 AM
Canuck1
Score: 100
Status: offline
Managed to glue on the leading and trailing edge balsa on to the wings. Tomorrow if time permits, I will shape them, and clean the wing up.
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to Canuck1)
       Post #: 52
RE: Byron Corsair Build - 1/26/2008 8:50 AM
Peter_OZ
Score: 108
Last Login: 3/17/2010
Status: offline
Craig, let me know how the test flight of it goes tomorrow!
hehe
cheers
Peter
fun police have struck again
Hide Signatures
       Post #: 53
RE: Byron Corsair Build - 1/26/2008 9:44 PM
Canuck1
Score: 100
Status: offline
No maiden as of yet, will be some time before that
I will make fake lights for the wingtips at a later date. However the next couple of steps has me install the wing tips. I have sanded them down, gave them a good wash. I marked the location as to where the lenses will go, and made some balsa pieces to form the backing of the wing tip lights. I will epoxy these into location, before I attach the wingtips. This will give me a good hard surface to work against when I get to that stage.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 54
RE: Byron Corsair Build - 1/26/2008 10:58 PM
Peter_OZ
Score: 108
Status: offline
mate a high intensity LED works atreat as a nav light, they are really easy to use, draw bugger al lcurrent and really look the goods on a warbird as does a functional landing light.
Consider this. You come off the downwind leg, gear down, half flaps, turn on to base while lowering full flaps then as you turn on to fianls with everything down and dirty you can see that landing light shining. Quite a few of the guys here have their warbirds down up like that and they look sensational, the crowd really likes it too.
Anyway just my biased viewpoint!
Hide Signatures
       Post #: 55
RE: Byron Corsair Build - 1/27/2008 12:16 AM
Canuck1
Score: 100
Status: offline
I think a landing light would be a great feature, just not to sure where it is located on the corsair. I will have to look at my books. I have glued in the support pieces for the wingtip lights.
Craig
Click for fullsize
< Message edited by Canuck1 -- 1/27/2008 12:18 AM >
Eat, Sleep, Fly
Hide Signatures
       Post #: 56
RE: Byron Corsair Build - 1/27/2008 12:20 AM
WhoDaMan
Score: 115
Last Login: 3/21/2010
Status: offline
here ya go
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by WhoDaMan -- 1/27/2008 12:32 AM >
Fly for fun,,,,, Live in Peace
Hide Signatures
       Post #: 57
RE: Byron Corsair Build - 1/27/2008 12:58 AM
Peter_OZ
Score: 108
Status: offline
quote:
ORIGINAL: Canuck1
Craig
go the functional nav lights
Hide Signatures
       Post #: 58
RE: Byron Corsair Build - 1/27/2008 2:38 AM
Canuck1
Score: 100
Status: offline
LOL
Great pics................however I dont see the landing light location
Eat, Sleep, Fly
Hide Signatures
       Post #: 59
RE: Byron Corsair Build - 1/27/2008 3:34 AM
WhoDaMan
Score: 115
Status: offline
I thought that was in in pic number 7, under the wing and then you have your fomation lights on the other wing, the multi color lights or, call the ball
Hide Signatures
       Post #: 60
RE: Byron Corsair Build - 1/27/2008 3:43 AM
Peter_OZ
Score: 108
Status: offline
Craig, I have about 6 or 7 really good book on the Corsair, I dig out apic of it post it for you. 3 views should show it as well, seem to recall it is outboard, similar to late model P47s.
cheers
Peter
Hide Signatures
(in reply to WhoDaMan)
       Post #: 61
RE: Byron Corsair Build - 1/27/2008 3:58 AM
US185Damiani
Score: 100
Status: offline
THe landing light is retracted into the left wing. It extends out then turns on. look closely you'll see it.
www.goldenageair.org
Hide Signatures
       Post #: 62
RE: Byron Corsair Build - 1/27/2008 4:40 AM
WhoDaMan
Score: 115
Status: offline
tip
Click for fullsize
Hide Signatures
(in reply to US185Damiani)
       Post #: 63
RE: Byron Corsair Build - 1/27/2008 6:38 AM
Canuck1
Score: 100
Status: offline
Thanks for all the pictures and information.
I cleaned the leading edge up and it is roughly shaped. I needed to do this prior to getting the wingtips ready to install. I cut out the wing caps, shaped them and epoxied then to the end of the wing. I also inserted and epoxied the spar extension into location. When this is dry and cured, I will attach the glass, wingtip. Then the leading edge and trailing edge will be sanded to match.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 64
RE: Byron Corsair Build - 1/27/2008 7:53 PM
Canuck1
Score: 100
Status: offline
I have the wing tips dry fitted. Fairly snug............just not sure which epoxy to use to glue them on. Either 30 min, or should I go with the polyester resin, that I used for the bracing in the fuselage.
After they are attached I will sand the leading and trailing edge to shape.
Craig
Click for fullsize
Click for fullsize
< Message edited by Canuck1 -- 1/27/2008 7:54 PM >
Eat, Sleep, Fly
Hide Signatures
       Post #: 65
RE: Byron Corsair Build - 1/27/2008 9:45 PM
Canuck1
Score: 100
Status: offline
Starting to look like a Corsair
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 66
RE: Byron Corsair Build - 1/27/2008 10:33 PM
Peter_OZ
Score: 108
Status: offline
30 min should be fine
Hide Signatures
       Post #: 67
RE: Byron Corsair Build - 1/27/2008 11:52 PM
Canuck1
Score: 100
Status: offline
Thanks Pete
Eat, Sleep, Fly
Hide Signatures
       Post #: 68
RE: Byron Corsair Build - 1/28/2008 3:49 AM
AMA234
Score: 103
Status: offline
quote:
ORIGINAL: Canuck1
Craig
Remember that polyester resin will melt the foam!!
Newton's Law states "what goes up, must come down"... not always in one piece though.
Hide Signatures
       Post #: 69
RE: Byron Corsair Build - 1/28/2008 6:09 AM
Peter_OZ
Score: 108
Status: offline
even more reason to use epoxy!!
Hide Signatures
(in reply to AMA234)
       Post #: 70
RE: Byron Corsair Build - 1/30/2008 6:58 AM
Canuck1
Score: 100
Status: offline
It has been so darn cold here, -32 and -46, with the wind, have not done much lately. Since my last post I have attached the wing tips, and have installed the dowels in the root of the wing. The wings do not line up as nice as I would have wanted, so I will need to do a bit of work to make it acceptable
I glued in the forward dowel plywood and glassed it in tonight. I did not like the position for the forward dowel hole so I moved it back. Inserted the wing, and when I was happy, I glued it into position. I just wanted to make sure that the alignment was good. I will do the rear pin after the flaps are cut out, then I will make the wing fit better with some sanding, and filling.
Craig.
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 71
RE: Byron Corsair Build - 1/30/2008 7:45 AM
Peter_OZ
Score: 108
Status: offline
It has been so darn cold here, -32 and -46, . . .
gessus H Creest, how do you live there! We are shivvering when it gets down to about 15C.
Man that is brass monkey weather for sure.
Here we are swealtering in 35C , 85% humidity and have the aircon going flat chat 24/7
Feel for you mat e, I could not live there.
Hide Signatures
       Post #: 72
RE: Byron Corsair Build - 1/30/2008 2:24 PM
Rocketman612
Score: 100
Last Login: 3/19/2010
Status: offline
Craig,
Is there any check of wing incidence at this point??
I know the wings need to line up with the fiberglass wing root but you said it isn't as good as you would like. Are you talking about the seam gap if any or the matching of the sheeting to the wing root?
Pete
PS stay warm
"Remember, all im offering is the truth, nothing more..."
Morpheus
Hide Signatures
       Post #: 73
RE: Byron Corsair Build - 1/30/2008 11:14 PM
Canuck1
Score: 100
Status: offline
I find that the plywood on the root end of the wing is not a good fit. Need to add some balsa on the bottom to bring it flush with the ply. Not a huge issue, just a bit more work. I was expecting a perfect fit, but this usualy is never the case. The leading edge matches real good and the trailing edge is slightly above the fibreglass part. This will be fixed when the flaps are done.
Craig.
Eat, Sleep, Fly
Hide Signatures
(in reply to Rocketman612)
       Post #: 74
RE: Byron Corsair Build - 2/1/2008 4:07 AM
Canuck1
Score: 100
Status: offline
Started cutting out the control surfaces on the wing. Starting with the ailerons. I drew them out on both top and botom of the wing. With a small saw blade, I cut the balsa on both top and bottom as well as the trailing edge. Then I used a small foam cutter, followed the balsa cuts, and voila.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.246RCU1
