RE: Byron Corsair Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Byron Corsair Build
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Byron Corsair Build - 1/26/2008 4:05:40 AM
Canuck1
Status: offline
I took the wings out of the shucks, trimed back the balsa to the foam and sanded it smooth. Next I will add the balsa leading and trailing edges.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Eat, Sleep, Fly
(in reply to Peter_OZ)
       Post #: 51
RE: Byron Corsair Build - 1/26/2008 6:17:10 AM
Canuck1
Status: offline
Managed to glue on the leading and trailing edge balsa on to the wings. Tomorrow if time permits, I will shape them, and clean the wing up.
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
(in reply to Canuck1)
       Post #: 52
RE: Byron Corsair Build - 1/26/2008 8:50:25 AM
Peter_OZ
Status: offline
Craig, let me know how the test flight of it goes tomorrow!
hehe
cheers
Peter
       Post #: 53
RE: Byron Corsair Build - 1/26/2008 9:44:31 PM
Canuck1
Status: offline
No maiden as of yet, will be some time before that
I will make fake lights for the wingtips at a later date. However the next couple of steps has me install the wing tips. I have sanded them down, gave them a good wash. I marked the location as to where the lenses will go, and made some balsa pieces to form the backing of the wing tip lights. I will epoxy these into location, before I attach the wingtips. This will give me a good hard surface to work against when I get to that stage.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
       Post #: 54
RE: Byron Corsair Build - 1/26/2008 10:58:29 PM
Peter_OZ
Status: offline
mate a high intensity LED works atreat as a nav light, they are really easy to use, draw bugger al lcurrent and really look the goods on a warbird as does a functional landing light.
Consider this. You come off the downwind leg, gear down, half flaps, turn on to base while lowering full flaps then as you turn on to fianls with everything down and dirty you can see that landing light shining. Quite a few of the guys here have their warbirds down up like that and they look sensational, the crowd really likes it too.
Anyway just my biased viewpoint!
       Post #: 55
RE: Byron Corsair Build - 1/27/2008 12:16:06 AM
Canuck1
Status: offline
I think a landing light would be a great feature, just not to sure where it is located on the corsair. I will have to look at my books. I have glued in the support pieces for the wingtip lights.
Craig
Click for fullsize
< Message edited by Canuck1 -- 1/27/2008 12:18:40 AM >
Eat, Sleep, Fly
       Post #: 56
RE: Byron Corsair Build - 1/27/2008 12:20:49 AM
WhoDaMan
Status: offline
here ya go
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by WhoDaMan -- 1/27/2008 12:32:08 AM >
Fly for fun,,,,, Live in Peace
       Post #: 57
RE: Byron Corsair Build - 1/27/2008 12:58:35 AM
Peter_OZ
Status: offline
quote:
ORIGINAL: Canuck1
Craig
go the functional nav lights
       Post #: 58
RE: Byron Corsair Build - 1/27/2008 2:38:10 AM
Canuck1
Status: offline
LOL
Great pics................however I dont see the landing light location
Eat, Sleep, Fly
       Post #: 59
RE: Byron Corsair Build - 1/27/2008 3:34:16 AM
WhoDaMan
Status: offline
I thought that was in in pic number 7, under the wing and then you have your fomation lights on the other wing, the multi color lights or, call the ball
       Post #: 60
RE: Byron Corsair Build - 1/27/2008 3:43:13 AM
Peter_OZ
Status: offline
Craig, I have about 6 or 7 really good book on the Corsair, I dig out apic of it post it for you. 3 views should show it as well, seem to recall it is outboard, similar to late model P47s.
cheers
Peter
(in reply to WhoDaMan)
       Post #: 61
RE: Byron Corsair Build - 1/27/2008 3:58:29 AM
US185Damiani
Status: online
THe landing light is retracted into the left wing. It extends out then turns on. look closely you'll see it.
A good landing is one you can walk away from, but, a great landing is when you can re-use the airplane.... immediately
       Post #: 62
RE: Byron Corsair Build - 1/27/2008 4:40:12 AM
WhoDaMan
Status: offline
tip
Click for fullsize
(in reply to US185Damiani)
       Post #: 63
RE: Byron Corsair Build - 1/27/2008 6:38:55 AM
Canuck1
Status: offline
Thanks for all the pictures and information.
I cleaned the leading edge up and it is roughly shaped. I needed to do this prior to getting the wingtips ready to install. I cut out the wing caps, shaped them and epoxied then to the end of the wing. I also inserted and epoxied the spar extension into location. When this is dry and cured, I will attach the glass, wingtip. Then the leading edge and trailing edge will be sanded to match.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
(in
