Canuck1
Been looking at the flap linkage, servo location, rear dowel plate location, etc. I have seen some previous pictures of the set up. Seems relatively straight forward, however............. Servo location, how deep into the wing from the edge. There is two linkages running off the servo, does one go behind the rear pin mounting hole, and one in front? It also seems that some relief will need to be cut, for the servo wheel, and the linkage that goes to the outboard servo, in the root of the slide in wing. I have also noticed that the rear pin will need to be moved forward from the mark located on the root cap, as it does interfer with the flap section. I needed to remove my rear pins when cutting out the flaps. I am looking for some comments on the set up, and it seems that the rear pin is important for alignment. Craig.
_____________________________
Eat, Sleep, Fly
