RE: Byron Corsair Build
Tower Hobbies
Logged in as Guest
Users viewing this topic: Doolittleraider
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Byron Corsair Build
Page: <<   < prev  3 4 5 [6] 7 8 9 10 11 12   next >   >>
Login
RE: Byron Corsair Build - 2/13/2008 3:05:59 AM
Peter_OZ
Status: offline
I thought it would be easier, You may still need to feather with blade putty after you glass, depends on how you go initially
yeah I like the fury too, quietly working away on the tail feathers
_____________________________
www.petenplanes.com.au
(in reply to Canuck1)
       Post #: 126
RE: Byron Corsair Build - 2/13/2008 7:13:53 AM
Canuck1
Status: offline
Glued some balsa sheets together for the fill. I will cut them at a length of 6 inches. Pre sand the outboard edge prior to instalation. This will give me a nice taper, so I will not need as much fill. After that I will use some fill, and carry on with the wing work. It should turn out pretty good. When it is all glassed you will never know. I noticed this when I was doing the construction so I ensured any filling would be on the bottom, so it will be not as noticeable
Craig.
Eat, Sleep, Fly
(in reply to Peter_OZ)
       Post #: 127
RE: Byron Corsair Build - 2/13/2008 7:31:02 AM
Peter_OZ
Status: offline
egg sell ant!
       Post #: 128
RE: Byron Corsair Build - 2/14/2008 4:07:48 AM
Canuck1
Status: offline
Worked on the filler panels for the bottom of the wing. Sanded the edges for a nice long taper. Glued them on and have applied my first layer of filler. When this dries I will apply more filler covering a larger area to reduce the slope angle.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
       Post #: 129
RE: Byron Corsair Build - 2/14/2008 4:39:03 AM
Peter_OZ
Status: offline
that should work well and be light too
       Post #: 130
RE: Byron Corsair Build - 2/14/2008 7:05:15 AM
Canuck1
Status: offline
Yes Peter, light, and it looks pretty good. I put a second coat on tonight. I used a 6in drywall knife, and it has feathered out nicely. Tomorrow I will give it one more light skim coat and it will be good to go.
Craig.
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
       Post #: 131
RE: Byron Corsair Build - 2/14/2008 11:45:25 AM
fockewulf37
Status: offline
Craig, What kind of filler are you using on the wing. If its the lightweight spackle once fiberglassed it will separate from the wood once it gets hot one time..in the sun... I just can't tell from the pictures...
Your build is looking good . I had a friend that built 4 or 5 of these he really loved the plane...
ty
       Post #: 132
RE: Byron Corsair Build - 2/14/2008 4:12:36 PM
MarvinLoomis
Status: offline
[image][/image]
(in reply to fockewulf37)
       Post #: 133
RE: Byron Corsair Build - 2/14/2008 6:18:49 PM
Canuck1
Status: offline
FW
Yes I am using the lightweight spacle. I have never had an issue in the past with this stuff releasing, especially after glassing. Most of it will be sanded down anyhow, after I install it and sand the shape. I figured I would get it all built up before I sand using the fuselage section, as a guide for a good fit.
Craig.
Eat, Sleep, Fly
(in reply to MarvinLoomis)
       Post #: 134
RE: Byron Corsair Build - 2/14/2008 6:38:01 PM
Check6
Status: offline
I have always used the regular Dap Vinyl Spackle. I find it goes on easier and sands beautifully to a feather edge. The lightweight spackle seems to have a grainy texture. Once glassed it has never separated. If you have had good luck with the light, by all means use what you are comfortable with. BTW Craig, the Corsair looks awesome, excellent craftsmanship.
Fred
       Post #: 135
RE: Byron Corsair Build - 2/14/2008 6:58:21 PM
Canuck1
Status: offline
Thanks Fred
You are right about the grainy texture. The only issue that I do have with it is that sometimes balls up as you sand. I just take my time as I sand it to a good feathered edge. Never tried the Dap Vinyl Spackle before. Sounds like a good product, may have to check it out.
Craig.
Eat, Sleep, Fly
(in reply to Check6)
       Post #: 136
RE: Byron Corsair Build - 2/14/2008 7:43:01 PM
fockewulf37
Status: offline
I switched to the 2 part spotting buddy on straight balsa or even use the Elmers wood filler... both are light weight and are tougher than the spackle. I have had the spackle release on a curve after being glassed and exposed to heat of a good sunny day....
Anyway its looking great ...Keep up the good work...
Ty
       Post #: 137
RE: Byron Corsair Build - 2/14/2008 9:06:11 PM
MarvinLoomis
Status: offline
Hi Craig. Told you I'd get you some pics of the gear door on my Corsair, so here ya go. Hope you can see what I'm talking about by the pictures. I used a Micro air switch and scale cylinders from Bob Violet models. I mounted an air cylinder to each door, when the retracts are retracted, one side contacts the micro air switch which triggers the gear door cylinders to close. It works pretty slick.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 138
RE: Byron Corsair Build - 2/14/2008 9:26:02 PM
Canuck1
Status: offline
Thanks for posting those pictures. It gives me some good idea's and options for myself, as well as other viewers. I take it those cylinders pivot when they are in operation. How much clearance do you have with the tires?
Craig.
Eat, Sleep, Fly
       Post #: 139
RE: Byron Corsair Build - 2/14/2008 9:52:20 PM
MarvinLoomis
Status: offline
No they don't pivot, they are pretty much stationary. They move a small amount but pretty much stay where they are mounted. Those cylinders come in different lengths. If you look at the Bob Violet literature in the first pic you can see the different sizes. Kinda hard to read but its there.
