RE: Byron Corsair Build
Tower Hobbies
Logged in as Guest
Users viewing this topic: ChrisK-RCU
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Byron Corsair Build
Page: <<   < prev  1 2 3 4 5 6 [7] 8 9   next >   >>
Login
RE: Byron Corsair Build - 2/17/2008 4:11:33 AM
Canuck1
Status: offline
Still plugging away on the trailing edge plywood. Took a while to complete the sanding, now I just need to make sure everything lines up well. I may have to sand a bit of the ailerons for a nice tight fit. Putting the ailerons in after the plywood is in location should prove interesting.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Eat, Sleep, Fly
(in reply to Canuck1)
       Post #: 151
RE: Byron Corsair Build - 2/17/2008 4:22:13 AM
Peter_OZ
Status: offline
excellent work mate, I had to do a little sanding on my elevators on the Sea Fury to ensure smooth rotation. By the way I like your sanding tool. Very good. I just use a straight edge taped in place then use my permagrit tool to knock it back. Once I have a little depth the straight edge is not needed.
The permagrit gets doen to the depth very quickly.
Well back to the Sea Fury.
       Post #: 152
RE: Byron Corsair Build - 2/17/2008 5:10:17 PM
Canuck1
Status: offline
I wanted to make a wing bracket, to hold the wings on in the folded position. This will give me more room to work as I progress with the build, and it also looks cool I made a female end that the wing slides into, and in turn this slides into the fuselage. Turned out pretty good, just need to glass it for strength.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
(in reply to Peter_OZ)
       Post #: 153
RE: Byron Corsair Build - 2/17/2008 8:58:08 PM
Peter_OZ
Status: offline
do I detect the possibility of a wing fold mechanisim being contemplated?
       Post #: 154
RE: Byron Corsair Build - 2/17/2008 10:07:55 PM
Rocketman612
Status: offline
quote:
ORIGINAL: Peter_OZ
Ya he's thinking about it LOL If he keeps looking at her like that every time he goes in the shop he'll be bitten soon.
Great craftsmanship
Pete
"Remember, all im offering is the truth, nothing more..."
Morpheus
       Post #: 155
RE: Byron Corsair Build - 2/17/2008 10:17:56 PM
Canuck1
Status: offline
A wing folding mechanism would be nice, just dont have the will to do that. Maybe another build
Trailing edge plywood is glued into location on the wings. Need to work on the flap hinging, aileron servo pocket, and the linkage for the aileron. Decided to put the gear in, slide on the tail and cowl, just to see how she looks. I am getting excited about this plane.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
(in reply to Rocketman612)
       Post #: 156
RE: Byron Corsair Build - 2/17/2008 10:56:03 PM
MarvinLoomis
Status: offline
The birds lookin great Craig! Think you'll be pleased with its flight performance. Sure am with mine! Good Build!
       Post #: 157
RE: Byron Corsair Build - 2/17/2008 11:33:09 PM
Peter_OZ
Status: offline
quote:
ORIGINAL: Canuck1
Craig
bzzztttttttt brrrrrrrrrrr clunk can just just see those wings slowly folding and unfolding
Just think how excited you will be then . . .
       Post #: 158
RE: Byron Corsair Build - 2/18/2008 2:36:30 AM
dragoonpvw
Status: offline
Hi Craig,
Here are the pics of my wing setup. I have the same pin at the front, as per instructions. At the trailing edge of the outer wing, I have a ply tab with a 6/32 blind nut in it. I then have a reinforced hole at the same point in the inner wing . The allen screw goes through the wing and holds it tight. Also preventing the wing slipping out if the main bracket screw gets loose. I have uploaded pictures of one other thing that I added myself. The switch / filler hatch. It is in the position of the full scale fuel tank and follows its panel line. Lots of room and easy to fill air fuel and flip the switches.
good luck
Paul
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
In this world, Elwood, you must be oh so smart or oh so pleasant
Well, for years I was smart. I recommend pleasant
       Post #: 159
RE: Byron Corsair Build - 2/18/2008 3:40:59 AM
Canuck1
Status: offline
Paul
Great pictures that you posted. I was thinking of the tounge method as well, looks very simple. Did you have any issues with the slitter plate to the outer flap? That looks as if it would be a much simpler set up than what the plans call for. I have been toying with the idea of making my aileron linkage hidden. Did you hide your linkage of go with the method stated in the plans?
Craig
Eat, Sleep, Fly
(in reply to dragoonpvw)
       Post #: 160
RE: Byron Corsair Build - 2/18/2008 7:09:10 AM
Canuck1
Status: offline
Spent the remainder of the evening installing the flaps to the outer wing panel. Hinges are in and the final adjustment will be done after glassing and primer. I need to build up some parts of the edges of the flaps to ensure an even edge all around. I still need to make a decision on my aileron linkage set up....................I will think about this for a bit.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Canuck1 -- 2/18/2008 7:11:00 AM >
Eat, Sleep, Fly
       Post #: 161
RE: Byron Corsair Build - 2/18/2008 2:13:55 PM
rschaffer
Status: offline
Canuck1,
I tried to emulate a scale actuator set-up on my Byron Corsair (aileron pushrod was hooked to 1/2 a hinge point in the top of the leading edge of the aileron, like the real bird). Set-up provided no stability around neutral. First flight with that system cause severe flutter in the outer wing panels. She looked like a bird. Modified after the first flight to have horns on the outside of the ailerons. This stopped the flutter problem in it's tracks. I have a friend who tried the carbon fiber rod slipping mechanism on a Top Flite GS Corsair, and he didn't like that system. It didn't provide enough throw.
I have a second IB Corsair in the beginning stages of construction, and plan to give the counterbalanced aileron system a harder look. Also, I set up the flaps the way the plans call for, and had no trouble. They work wonderfully, and make this one of the easiest Corsairs to land!
Great job on the build, and I can't wait to see the finished process.
Damn the rain, let's go flying...
Russ - Corsair Brotherhood #14
       Post #: 162
RE: Byron Corsair Build - 2/19/2008 4:46:37 AM
dragoonpvw
Status: offline
hey Craig.
I took a few pics of my aileron setup. I also did a little diagram of the setup from the side view. Not too pretty but it gives you an idea. The horn is made by shaping the aileron inner end cap. then I use a hitec 5955TG 300 ounce titanium gear servo. I use hd ball links on each end to reduce slop. It is very positive right now and flies solid. the servo is mounted on the bottom of the servo box. getting the right geometry was the hardest part. I might go for the counter balance if I was you as I have them on the Byron hellcat that I have 1/2 finished. Anyway. If you decide to give it a try here you go.
good luck
Paul
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to rschaffer)
       Post #: 163
RE: Byron Corsair Build - 2/19/2008 5:09:49 AM
Canuck1
Status: offline
Paul
Great idea, never even thought about that method. It looks like a pretty good setup. I will probably use the counter balance. After all the reading I have been doing, it is the safest bet. Thanks for posting those pictures, makes it a lot easier to invision
Craig
Eat, Sleep, Fly
       Post #: 164
