RE: Byron Wedell Williams Racer Build
Tower Hobbies
Logged in as Guest
  Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $99.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Byron Wedell Williams Racer Build
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Byron Wedell Williams Racer Build - 2/17/2008 8:10:55 PM
hallstro
Status: offline
Thanks for taking the time to post updates. Your workmanship looks terrific. This is a fascinating kit to build and you will have one sweet flyer when you are finished.
Dave
(in reply to Rocketman612)
       Post #: 26
RE: Byron Wedell Williams Racer Build - 2/18/2008 1:05:32 AM
Rocketman612
Status: offline
Dave,
Thanks for the kind words. I really enjoy building and hope people are enjoying the thread.
The UPS man arrived with a shipment of servos and the Rx. Will be using PCM for the failsafe aspect. Changed my servo selection some. I went with the Futaba S3152 for the Ailerons.
http://www.servocity.com/~servo/html/s3152.html
Futaba S9202 for the Rudder and Elevator halves.
http://www.servocity.com/~servo/html/s9202_heli_air_ball_bearing.html
Standard BB servo for the throttle. Will be running at 6v so no shortage of muscle. Likely overkill but I saw a friends biplane auger in when he stalled his servos in a power dive. Similar weight and power to the WWR, he was running 4.8v and standard servos.
Pete
Click to see fullsize image.
Click for fullsize
_____________________________
"Remember, all im offering is the truth, nothing more..."
Morpheus
(in reply to hallstro)
       Post #: 27
RE: Byron Wedell Williams Racer Build - 2/18/2008 1:35:28 AM
DAN REISS
Status: offline
Thanks for the great build. I've seen several fly and they were spectcular. Dan
       Post #: 28
RE: Byron Wedell Williams Racer Build - 3/25/2008 3:30:18 AM
Rocketman612
Status: offline
Well the build is progressing. Got off track with spring Honey Do's
The Horizontal Stab is pretty straightforward. The Keel components are butt glued then the TE 1/2 in balsa followed with the leading edge balsa parts. I glued the 4in wide center balsa after marking the cut line for the LE section. Cap strips added. I just need to add the 1/8 ply supports for the stab flying wires.
Pete
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Morpheus
(in reply to DAN REISS)
       Post #: 29
RE: Byron Wedell Williams Racer Build - 3/25/2008 3:36:31 AM
Rocketman612
Status: offline
Elevators are also per plans. I did cut the LE balsa too long but was able to notch it out and properly place the E2 balsa and lite ply parts. The TE balsa was placed and then the cap strips. I lined up the strips based on the corresponding stab strip.
Pete
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Rocketman612 -- 3/25/2008 3:39:25 AM >
Morpheus
       Post #: 30
RE: Byron Wedell Williams Racer Build - 3/25/2008 3:01:28 PM
51-D GUY
Status: offline
Hello Rocketman612,
Looking good so far !
Just wanted to let you know , I live about 10 minutes away from the muesuem where the Flying replicas of the Wedell / Williams
Racers are , if you are interested in some pics / documentation of the real thing, they have both the Red Lion & # 44 , There is also one that's Black & White, Sorry i dont have any more info of this one For i t has just recently arrived , & I havent seen it yet,
If interested , Let me know .
51-D GUY
       Post #: 31
RE: Byron Wedell Williams Racer Build - 3/25/2008 6:41:08 PM
Rocketman612
Status: offline
quote:
ORIGINAL: 51-D GUY
Hello Rocketman612,
51-D GUY
Thanks for the offer. I have someone going to the museum to do a photoshoot of the WWR planes when the exhibit opens again. It's been closed for renovations for the past few months.
Glad your enjoying the build. Jump in anytime with suggestions or tips.
Pete
Morpheus
(in reply to 51-D GUY)
       Post #: 32
RE: Byron Wedell Williams Racer Build - 3/28/2008 1:25:49 PM
Rocketman612
Status: offline
Found some more photo's these are the Modell 44 Wedell-Williams was built by Jim Clevenger
Pete
Click for fullsize
Click for fullsize
Click for fullsize
Morpheus
       Post #: 33
RE: Byron Wedell Williams Racer Build - 3/28/2008 11:02:11 PM
Rocketman612
Status: offline
Added the 1/8 ply plates to anchor the Stab flying wires. Used the balsa circle scrap as filler where the plates overlapped the lightening holes. Rough sanded the elevators and started the Rudder.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Morpheus
       Post #: 34
RE: Byron Wedell Williams Racer Build - 4/3/2008 6:31:50 AM
PTS
Status: offline
Was this an actual Byron Kit or the offering from Iron Bay?
Perry
       Post #: 35
RE: Byron Wedell Williams Racer Build - 4/3/2008 2:22:26 PM
Rocketman612
Status: offline
quote:
ORIGINAL: PTS
Perry
It's a Byron kit. The quality is very very good.
Pete
Morpheus
(in reply to PTS)
       Post #: 36
RE: Byron Wedell Williams Racer Build - 4/7/2008 3:37:08 AM
Rocketman612
Status: offline
Finished the Horizontal stab and elevators as well as most of the Rudder. To get a consistent shape I used a piece of pvc pipe cut it's length with sandpaper glued on. Same done on the elevators. Drill pressed the holes for the blind nuts. Table saw for the bevel and set the hinges leaving no gap. The blind nut needed to be trimmed where it was overlapping the bevel.
The Rudder ribs were missing so they were made from scrap stock and placed. Top and bottom edge balsa added and the rough airfoil shape sanded.
Pete
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
