Strange A123 issue
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> Strange A123 issue
Page: [1]
Login
Strange A123 issue - 1/14/2008 2:49:20 AM
GhostRider32
Status: online
Hey all,
I made a 3S1P 2300 pack and for some reason, 1 cell is always about .5 volt higher than the others. How do I get them to balance even? The 0610i gets all 3 cells even at about 3.4v but then the cells spread to approx. 3.7, 3.4 and 3.4 or thereabouts. The cells always discharge to about 2.7, 2.2 and 2.2. Any ideas?
       Post #: 1
RE: Strange A123 issue - 1/14/2008 4:48:30 AM
SinCityJets
Status: offline
gr,
I wouldn't worry about it too much. If you are balance charging them, that is all you can really do. After having sold well over 500 packs, I have come across cells that start off at 1.5 volts and seen them as high as 3.8 right out of the pack. I would just say you have one REALLY healthy cell!
_____________________________
www.sincityjets.com
A123 Battery Packs / Trigger Valves / Stretchy Covers / Smart-Fly / Fei Bao / JetCat / Jet Central
(in reply to GhostRider32)
       Post #: 2
RE: Strange A123 issue - 1/14/2008 5:00:48 AM
jasonwang3a
Status: offline
please balance charge your 3S liFe pack with balane charge such as 630B or 680B at www.chargery.com , if the cell voltage is the same after charging over, a few minutes late, the cell voltage beome defferent, please check carefully the cell impedance, if the cell impedance is very different, whether charge or discharge, the cell voltage will be diifferent. so before assembling the battery, it is best to assemble the cells with the same impedance, same voltage and same capacity.
Jason
       Post #: 3
RE: Strange A123 issue - 1/14/2008 11:01:09 AM
coro_sk
Status: offline
You have 0610i which is a good balancing charger, You are not using balancer connection and balance mode?
You can do it at least once..
Good and recommended practice is to fully charge each cell separately when new pack is made, or long time stored pack is brought to life.
(in reply to jasonwang3a)
       Post #: 4
RE: Strange A123 issue - 1/14/2008 12:55:29 PM
GhostRider32
Status: online
Yes, I sm using the balancer. I will dissassemble the pack to check impedance.
(in reply to coro_sk)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
