RE: MVVS 152
Tower Hobbies
Logged in as Guest
  Printable Version
BCMA-42 Pro - RTR
Seller:  blackbaron
Details:   $325.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> RE: MVVS 152
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: MVVS 152 - 2/2/2008 12:48:17 AM
octanehuffer
Status: offline
Come on. Take one for the team. You have specs for ZDZ, DA, 3W, and BME. Buy the 85, make it non recognizable so you dont blow your cover, test the hell out of, and throw it away?
Are there any plans in the future for an MVVS 85cc sized engine?
_____________________________
QQ 120" Yak, QQ 86" Evolution, QQ 69" Saito 1.25, QQ 49" 32SX, QQ E-Yak, H9 T-Craft G-26, etc
(in reply to pe reivers)
       Post #: 26
RE: MVVS 152 - 2/2/2008 8:29:41 AM
Hans Meij
Status: offline
quote:
ORIGINAL: octanehuffer
With link to image in this thread.
(in reply to octanehuffer)
       Post #: 27
RE: MVVS 152 - 2/2/2008 12:23:01 PM
wifpwcf
Status: offline
thanks pe email received & sent one back,,be great to hear the the toy fair gossip about mvvs.
looking forward to my new 152 now
here is a vid from today guys the 116 in the 40% is fun in the wind
cheers glen
http://www.youtube.com/watch?v=vJHTmN03i_0
TEAM AUSTARS,TEAM TO MUCH FUN CLUB
TEAM BIG COURAGE DIAMONDS
(in reply to Hans Meij)
       Post #: 28
RE: MVVS 152 - 2/8/2008 7:33:42 PM
janch
Status: offline
Hi,
I was on exibition. You can see here first picture.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to wifpwcf)
       Post #: 29
RE: MVVS 152 - 2/8/2008 8:22:40 PM
Hans Meij
Status: offline
Thanks for the pics
(in reply to janch)
       Post #: 30
RE: MVVS 152 - 2/9/2008 1:08:10 AM
octanehuffer
Status: offline
Any specs for the 152?
       Post #: 31
RE: MVVS 152 - 2/9/2008 9:55:21 AM
wifpwcf
Status: offline
yehaaaaaaaaaaaaaaaaa thanks for the pics roumor just turned reality in my eyes now
cheers glen
       Post #: 32
RE: MVVS 152 - 2/9/2008 11:45:21 AM
pe reivers
Status: offline
quote:
ORIGINAL: janch
Hi,
Jan,
Yesterday, I have been in the MVVS corner looking out for you from 12.00 - 15.00!!!! Where were you? I have met the new UK importer, and others, but not you.
OK guys, here are the scoops:
New:
mvvs26, updated with larger crankpin. now also available with side spark plug (special head)
mvvs 40 Modified 35 with larger bore
MVVS 45, redesigned front bearing lubrication
MVVS 80 new engine, bore48mm stroke 44mm 2220 grams without ignition, props 26x10 to 27x10
MVVS 80 twin spark, new engine, bore48mm stroke 44mm 2220 grams without ignition, props 26x10 to 27x10
MVVS 152, new engine, bore 48mm stroke 42mm, 3530 grams without ignition, props 29x10 to 32x10
MVVS 152 twin spark, new engine, bore 48mm stroke 42mm, 3530 grams without ignition, props 29x10 to 32x10
New side muffler for the 45 cylinders and up, builds more compact and as close to the engine side as possible
And of course, there was gossip, which for the moment I keep to myself.
Most of the engines now have the possibility to add a shot of lubrication to the front bearing. Extra clearance has been added between crank and housing, so more oil can get up front. The 45 even has a special oil bore leading to the front bearing.
Edit:
And this collection in the background makes the trip well worth the effort, will post detail pictures asap
Click for fullsize
< Message edited by pe reivers -- 2/9/2008 12:02:44 PM >
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to janch)
       Post #: 33
RE: MVVS 152 - 2/9/2008 12:17:14 PM
janch
Status: offline
Hi Friend ,
I saw you. You spoke with UK partners. I was there with ION PRo plus producer. We turned around exibition place betwen 1O up to 16 oclock.
Jan
       Post #: 34
RE: MVVS 152 - 2/9/2008 3:28:23 PM
Hans Meij
Status: offline
quote:
ORIGINAL: pe reivers
Pe, I think you shipped me a prototype of this 40 by accident when I bought a 35 a few years ago, because my 35 is running like a champ and doing 500rpm more then MVVS claims that it is capable of on a pipe. (mine is running 7800 rpm on a MZ 20*10)
So, I'm surprised that they have been able to improve the already superb 35.
       Post #: 35
RE: MVVS 152 - 2/9/2008 8:28:18 PM
pe reivers
Status: offline
Here are the 80 and 152
Both can have single spark plug cylinders, or twin sparks.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 36
RE: MVVS 152 - 2/10/2008 1:10:39 PM
MalaysianFlyer
Status: offline
Is there any chance we can get the factory tested rpm figures?
       Post #: 37
RE: MVVS 152 - 2/10/2008 2:40:53 PM
pe reivers
Status: offline
Look at the props that are advised. That tells the story. Larger props, stronger engine. Knowing MVVS, they won't take quite good as good enough.
(in reply to MalaysianFlyer)
       Post #: 38
RE: MVVS 152 - 2/11/2008 1:37:30 PM
saflyer
Status: offline
My 116 runs well with a 30x10 Menz prop. I would expect the 152 to be in the range of a 34-36" prop.
What engine could we compare the 152 against? How will it fair in a comparison to 180 or 200cc engine?
       Post #: 39
RE: MVVS 152 - 2/11/2008 11:45:25 PM
pe reivers
Status: offline
a 32x12 at 6000 would be 19HP, a 36x12 at 5500 requires 24 horses to turn. A 3W 200 will produce about 18 hp (on paper)
Expectations are not always realistic, nor is it realistic to ask for a comparison with 200cc engines.
However, if you give me < real life data > on 180cc engines, I will soon know how the 152 compares.
(in reply to saflyer)
