RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece wing and more
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece wing and more
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece ... - 2/15/2008 7:40:09 AM
ram3500-RCU
Status: offline
Got her up on her feet for a check on the nose gear strut length needed.
Click to see fullsize image.
Click for fullsize
(in reply to ram3500-RCU)
       Post #: 51
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece ... - 2/18/2008 6:03:52 PM
ram3500-RCU
Status: offline
While waiting on parts, I installed the radiator housings on the booms. With the curved bottoms, it was easy to mount them parallel to the thrust line as they should be.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 52
RE: Nitro 90" P-38 (1/7 scale) with 3 piece wing ... - 2/18/2008 7:01:33 PM
FHD
Status: offline
hi
where did you buy your clink wrap from,what type of store/
thanks
_____________________________
FRANK
       Post #: 53
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece... - 2/18/2008 7:12:33 PM
cobi.p
Status: online
hello ram3500
i was thinking that my shop is a mess , well , you give me some hope ....
good work
cobi
i believe in " KISS " - ( Keep It Simple Stupid )
building the don smith B-24 J 1/9 scale
(in reply to FHD)
       Post #: 54
RE: Nitro 90" P-38 (1/7 scale) with 3 piece wing ... - 2/18/2008 9:40:01 PM
ram3500-RCU
Status: offline
quote:
ORIGINAL: FHD
hi
thanks
I'm pretty sure Lowes, Home Depot, Walmart, among others have it. It is 6" stretch wrap and it will be in the moving/packaging supplies department.
(in reply to FHD)
       Post #: 55
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece... - 2/18/2008 9:41:46 PM
ram3500-RCU
Status: offline
quote:
ORIGINAL: cobi.p
hello ram3500
good work
cobi
What is scary, I straitened up some before I took these pictures.
(in reply to cobi.p)
       Post #: 56
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece... - 2/19/2008 12:04:58 AM
Edwin
Status: offline
I saw some at walmart the other day right where he said you could find it. In the packing material section of office supplies.
Edwin
       Post #: 57
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece... - 2/20/2008 3:24:46 AM
n9331v
Status: offline
Check
Mooney N9331V
(in reply to Edwin)
       Post #: 58
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece ... - 2/20/2008 7:00:08 PM
ram3500-RCU
Status: offline
I applied some Sno White light weight body filler to the glassed areas and all I need do now is sand this out and I think I'm ready for the finish on the bottom in Grey. Still waiting on my nose gear to show up and I don't want to cut the gear door out till I have it. I weighed what I have so far including all the loose components, to see how I was doing on my target of 16lbs. So far, she weighs in at 13lbs 12oz which includes the two mounted engines. Still to add is the nose gear, gear door cylinders, air system with the sequencing valve, cockpit detail, spinners and props, and the Rx battery. Looks like I'm not going to get under 16lbs.
On the colors, I have decided to stay with the Olive Drab but I will go with the Grey on the bottom and add invasion stripes. Also panel lines weathering and other details will be added. When I'm done, this won't look much like the stock Nitro P-38, I hope. It will be a nice size 90" war bird that I won't have thousands of dollars invested in.
I'm hoping to make our local mall show with her. I still have about a month to get her ready.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ram3500-RCU -- 2/20/2008 7:37:50 PM >
       Post #: 59
RE: Nitro Models 90" P-38 (1/7 scale) with 3 piece... - 2/21/2008 12:15:23 AM
ram3500-RCU
Status: offline
Fitted the outboard wing panels, and cut the access holes for the wing bolts. Works good and it is starting to look like something.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ram3500-RCU -- 2/21/2008 12:16:10 AM >
       Post #: 60
RE: Nitro Models 90" P-38 (1/7 scale) with 3 piece... - 2/21/2008 12:20:36 AM
ram3500-RCU
Status: offline
My pilot saw me fitting the wings today and is getting very anxious. He wanted a closer look. I told him it wouldn't be long and in the meantime, he could work out a little and maybe lose a few onces, cause we were going to need it. He told me not to worry because he could fly a Coke Machine if it had wings. I'm not so sure.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 61
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece... - 2/21/2008 2:10:27 AM
wingspar
Status: offline
Where did you get the pilot and how tall is he??
dave
       Post #: 62
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece... - 2/21/2008 2:33:20 AM
ram3500-RCU
Status: offline
Got him off eBay for $15. he is supposed to be 1/6 scale (12" tall), but measures closer to 11". I think he will still be OK in my P-38. He is fully articulated with every joint movable.
I asked the guy when I bought him if he was checked out in P-38s because the box says P-40 pilot.
He was made by Dragon Action Figure and is item #70093. The box also says New Generation Life Action Figures. He comes with full flight gear including the parachute, side arm with even a magazine clip and holster, wrist watch, goggles, and of course the May West.
The back of the box has the web site. It is WWW.dragon-models.com
Click for fullsize
Click for fullsize
< Message edited by ram3500-RCU -- 2/21/2008 2:35:51 AM >
(in reply to wingspar)
       Post #: 63
RE: Nitroplanes 90" P-38 (1/7 scale) with 3 piece... - 2/21/2008 3:50:04 AM
wingspar
Status: offline
I've got one of those 1/6 scale pilots too. They look great but are just to big for my 1/7 scale A-26.
Dave
