RE: LightFlite Bug    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Indoor & Micro RC Flight >> RE: LightFlite Bug
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: LightFlite Bug - 4/8/2008 1:47 AM
darticus
Score: 100
Last Login: 4/28/2012
Status: offline
The Bugs in the videos seem slow moving and they are able to do a roll so maybe speed is not my problem. Ron
http://www.youtube.com/watch?v=ShZs4QnlLZo&eurl=http://www.lightflite.com/
_____________________________
Thanks for your help Guys, FORGEDABOUTIT! Ron
Hide Signatures
(in reply to Flypaper 2)
       Post #: 126
RE: LightFlite Bug - 4/8/2008 2:44 AM
Flypaper 2
Score: 100
Last Login: 6/13/2013
Status: offline
That's the 47in. extra super large giant sized bug Roll rate is all in your choice in the setup of throws, as to how fast it rolls or how much ail.you give it.
Gord
Dreamed I was a muffler. Woke up exhausted.
Hide Signatures
(in reply to darticus)
       Post #: 127
RE: LightFlite Bug - 4/8/2008 3:23 AM
FERNDALE AIR FORCE
Score: 115
Last Login: 3/2/2012
Status: offline
Ron I have rates at 75%, which is about 2.25", full defection is about 3.25". I usually fly with my expo at 20%. I hope that is helpful.
Tim
"...never stop flying the airplane..."
Hide Signatures
       Post #: 128
RE: LightFlite Bug - 4/8/2008 3:53 AM
darticus
Score: 100
Status: offline
Hi Tim
Did 6 packs today, now I should do a 6 pack.
Still can't do a roll. I did get inverted by the wind and pulled out in a loop so that's something, at 10 feet. Really don't know what Expo means but mine is set at 65. Do you know what it means? The loops I'll get just got to get a little more nerve and speed. When I try to roll all I do is turn with a lean. Maybe I should have A closer setting to 100% on the flaps (aileron, elevon). Can you get a roll just by moving the right stick full right or full left? If so maybe its my flaps, they only move about 1 1/4 inch from flat. If I throw the 3 switches on my radio I would have full travel which might be too much. I could try the full travel, crash, than I should tell something about a roll.
What causes the servos to chatter? Flies fine but they flicker when standing still.
< Message edited by darticus -- 4/8/2008 3:55 AM >
Hide Signatures
(in reply to FERNDALE AIR FORCE)
       Post #: 129
RE: LightFlite Bug - 4/8/2008 5:13 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
Ron, many questions at once.
OK, first expo is the amount of sensitvity to the center of the stick. For example, 0% expo is pure stick movement, and on this plane pretty close to proportional. That is how I taught my self to fly this plane. The more expo you have the more gently the plane flies. For the DX radios that is + expo, for Hitec it is - expo. As I said earlier I use 20% expo, it gentles the plane a bit for minor flight adjustments. I lost the plane to a roof 3 times since I have had it. 2 of those time were when I was playing with 50+% expo. I have found a home at 20% expo, but am thinking of reducing it, maybe.
I think this is why loops and rolls are hard for you to do. By the time you have the stick in the correct position the plane is in a gentle turn, that turns into a dive due to the major last minute change. Your radio may have d/r for expo. Mine does not. I would recommend trying lower expo in stages. If you are really comfortable with the gentle turns, the difference will be huge if you drop to low expo fast. For example, I'm used to flip/rolling out of trouble. When I was playing with hi expo I was unable to do that. A flip/roll changes your direction in about 40".
Elevon deflection: According to the instructions you want between 2 1/4 low and 3 1/4 high. Mine are set about 2 1/4 for low. The easy way to adjust this is to measure up from the wing, mark your spot then keeping the ruler square, mark the rudder. You should be able to adjust that height with your radio. Adjusting the rate % higher should give you
more elevon travel. Try this before messing with your expo. I know that is too much expo for my radio, but you have a better radio.
Servo clicks: This is a problem I have left behind. I assume this is when the tx is on? If so the options are a carppy servo or poor connection, or interference from something else. Since you are using dx tech I doubt the latter. I tend to think it is going to be the servos themselves. I have hitec hs-55's on my bug with no issues at all.
Ron you might want to really look at the rc book, it has helped me a lot. I hope this is helpful.
Off to fly out some batteries,
Tim
Hide Signatures
       Post #: 130
RE: LightFlite Bug - 4/8/2008 3:41 PM
darticus
Score: 100
Status: offline
Thanks Tim
Maybe the Expo should be dropped on my to 30. I do have Dual Rates set so flap movement is adjusted. Switches in one one direction make flaps 50-60% active and switches the other way 100% active (rudder aileron, elevon). Maybe I should adjust these to 75% on the low side as movement only looks like 1 1/4 inch on aileron and elevon. Did you say you could do rolls at 40% expo? Guess I have to experiment!
Hide Signatures
       Post #: 131
RE: LightFlite Bug - 4/8/2008 4:52 PM
darticus
Score: 100
Status: offline
Got the nerve to flip the aileron and elevon switches so they both have 100% and elevator also has 100%. Wow! What a difference. Now loops are at will and tight small loops are doable. Have to still work on rolls! Still didn't move the Expo but this change is night and day. Have to be careful not to over turn. Should I just leave it at full???Have to experiment more and think about that expo setting, maybe 40% would be a good test from 65%. Thanks Ron
Hide Signatures
       Post #: 132
RE: LightFlite Bug - 4/9/2008 2:55 AM
darticus
Score: 100
Status: offline
ANOTHER QUICK QUESTION
What would cause the electric to cut out after the first 15 seconds of flight and come back on 30 seconds later and work fine for the total remainder of the flight? Ron
Hide Signatures
       Post #: 133
RE: LightFlite Bug - 4/9/2008 3:09 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
A loose battery connector in your radio??
Try raising your low rate, At speed high rates can be challenging. Try 75-80%?
Tim
Hide Signatures
       Post #: 134
RE: LightFlite Bug - 4/10/2008 5:34 PM
darticus
Score: 100
Status: offline
Hey Timster
I have the rates at 100%. All flap full travel. Any reason not to run this way? Still have expo at 65%. Thanks Ron
Hide Signatures
       Post #: 135
RE: LightFlite Bug - 4/11/2008 3:35 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
Ron, the only drawback is that at speed, 75% or more, mine gets squirrelly on full throws. I also use less expo, so my inputs come faster.
I got myself a new radio. Optic 6, the big brother of my flash 5, it has far more mixing ability than the flash 5 however.
Only one flight yesterday, it's a bit windy. Still blowing now.
Tim
Hide Signatures
       Post #: 136
RE: LightFlite Bug - 4/11/2008 3:52 AM
darticus
Score: 100
Status: offline
Hey Tim My Man
COOL RADIO! GOOD LUCK WITH IT! ABOUT TIME!
Got 7 packs in today but two days of rain coming. My Expo was at 65 and Ron at lightflite said go higher 70-75. can you tell me what would be the feel difference between 70 and your 20. It it quicker bursts at 20 or less? Is 20 slower or faster moving. I still haven't done a roll but plenty of loops.
How about fly time, I was getting almost 9 minutes with slow flying and 50% throws but now only getting about 6 minutes. Whats your fly times?
Hide Signatures
       Post #: 137
RE: LightFlite Bug - 4/12/2008 12:23 AM
darticus
Score: 100
Status: offline
Bug has a servo in it that chatters. Checked the gears and they are fine but still chatters but works fine. It actually moves the aileron real fast about 1/4 inch even during flight. Don't really notice during a flight. It is the servo as I checked against a new one. Anyone know why they chatter? Wonder if I can post in another section of RC UNIVERSE?
< Message edited by darticus -- 4/12/2008 12:28 AM >
Hide Signatures
       Post #: 138
RE: LightFlite Bug - 4/12/2008 3:13 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
Ron, just try out a little less expo. To me the times I tried 50 and 70 expo the controls felt really mushy compared to what I'm used to. My flight times are coming up to about 10 minutes each, now that the trim is better.
If your servo is chattering and the rx is good, something in the servo, either gears or wiring is going bad.
Tim
Big talk about battery life is proving wrong today. 6-7 minutes per battery. Near perfect conditions, light wind, sunny( I prefer some clouds) and about 72*. I'm flying high and far. Tim
< Message edited by FERNDALE AIR FORCE -- 4/12/2008 4:46 AM >
Hide Signatures
       Post #: 139
RE: LightFlite Bug - 4/12/2008 5:20 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
More battery observations. Batteries 1 and 2 have about 100 charge cycles on them, most of which are done back to back. They are giving me about 7 minutes each at 75% power on, and seem a bit sluggish. Battery 3, which I got about 2 weeks ago seems good to go for the full 10 minutes. I usually landed after 8 minutes to keep from over-extending the battery. So the question becomes, How many cycles will a battery take?
I assume most folks fly their bug once or twice a week, as this seems to be the normal pattern of flyers. With that math I have almost a years worth of flight from the batteries already. What is considered a good lifespan on lipo's?
Tim
Hide Signatures
       Post #: 140
RE: LightFlite Bug - 4/12/2008 6:18 AM
darticus
Score: 100
Status: offline
I better get some batteries at 6-7 packs a day. Ron
Hide Signatures
       Post #: 141
RE: LightFlite Bug - 4/13/2008 2:04 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
Ron, I don't think it's worth worrying about. The new battery is just that, new, and I was making time yesterday. If I flew a bit slower I would get a bit more time. That was more of a observation than a problem statement.
Tim
Hide Signatures
       Post #: 142
RE: LightFlite Bug - 4/13/2008 3:09 AM
Flypaper 2
Score: 100
Status: offline
I have a couple of Thunder Power 730 ma., 2 cells that are dated 06, and are still going strong. Probably not quite as much run time but the difference is hardly noticeable. As long as you don't run them right out (ESC is set for 3 volts per cell) , or try to draw to many amps, hard to do on a bug, , they will last a long time. Name brand batts. helps too.
Gord
Hide Signatures
       Post #: 143
RE: LightFlite Bug - 4/14/2008 3:50 PM
darticus
Score: 100
Status: offline
Hey guys
Whats the best batteries for the bug (buck). I need to get two. What about size 460mah or bigger 15c or bigger. What about a good price? Does Ron at Lightflite carry good batteries?
Hide Signatures
       Post #: 144
RE: LightFlite Bug - 4/14/2008 4:04 PM
nashtm
Score: 100
Last Login: 2/19/2013
Status: offline
I use Zippy 500mAh and polyquest 800mAh cells (2 cells) - I can feel the difference in weight between the 500 and 800mAh cells on the plane.
I think the smaller ones are better for inside - I normally fly in the early evening, I start with the 800mAh and if/when the breeze has died I use the smaller batts.
regards
Tim
Hide Signatures
       Post #: 145
RE: LightFlite Bug - 4/14/2008 4:47 PM
darticus
Score: 100
Status: offline
Do you have a special site to get them? Ron
Hide Signatures
(in reply to nashtm)
       Post #: 146
RE: LightFlite Bug - 4/14/2008 5:05 PM
nashtm
Score: 100
Status: offline
I got them from my LHS - I think getting good/known brands and light weight (due mainly to battery capacity) is the best approach.
regards
Tim
Hide Signatures
       Post #: 147
RE: LightFlite Bug - 4/16/2008 3:58 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
Ron, there are lots of places to get batteries. I like the batteries from Ron, and the price is good.
Tim
Hide Signatures
       Post #: 148
RE: LightFlite Bug - 4/16/2008 5:18 AM
darticus
Score: 100
Status: offline
Thats what I''ll do. Thanks
Hide Signatures
       Post #: 149
RE: LightFlite Bug - 4/20/2008 5:54 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
Speaking of the radio, WOW. I didn't think I would be able to tell the difference in the air, but I was wrong. The few times I flew the laser 6, I thought it was nice and crisp. Then I got the flash 5 and started using it all the time and got used to it. I guess the processor(s) for the sticks are faster. I feel like I have a better progression through the sticks, if that makes sense. For example the airhog bipe that is making the rounds has 7 steps from 0-full power. The flash might have fifty, the optic feels like 100 or truly proportional.
This translates to really crisp turns, and I will have some relearning to do. The bug would not fly at 50% on the flash, I needed to have closer to 60% to just sort of float it along. Now I can just float with barely steerage power, at 50%, right where it's supposed to. While a fancy radio won't automatically make you a superstar pilot or make a newby a practiced pilot, it will help tremendously in flying the plane as designed. I am truly impressed with the Optic 6.
OK, I cut that from a post on the B.O.C. thread, but the difference is quite noticable. I thought the flash 5 computer radio was great, and it is a good radio, but the difference is quite noticable. Similar to the dx6 radios i'm sure. And I have yet to figure out the advanced mixing , or to couple the right slider to the elevator trim, or even more trick mix the ele with the throttle, so that as I increase power the ele lowers a little to maintain even flight.
Battery 4 is ready and 5 is charging. I did not get my second charger this week, hopefully it will be at the PO on Monday.
Tim
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.563RCU1
