FERNDALE AIR FORCE -> RE: LightFlite Bug (2/28/2008 12:37 AM)
Ron, the esc appears to be set up for a pusher, just swap the wires and your fine. For the servos, from the rear, mine go right servo = ch 1, left servo = ch 2, esc = ch 3, and rudder = ch 4. This is on a fut/hitec system. Set your cg, I'm more comfortable with the 3 7/8 mark than the 4 1/8 mark right now, or you could cheat and split the difference. Yes to glueing the flex tube, no to glueing the attaching piece. Be cautious when glueing the flex tube. And don't glue the flex tube to the fuse, you should be able toturn the flex tube assy easilt on the axle. Ron, the builder, recommends a low set of rates, I'm still flying mine in that configuration. I made a small mark on the vert stab to check where I am. Does this make sense? Tim
