FERNDALE AIR FORCE -> RE: LightFlite Bug (4/1/2008 1:27 AM)
Nash, I do not think Ron participates on this thread or the one on RCG. I like the way yours is done up. Have you thought of submitting your pic to LightFlite? Guys, it's been really windy here for the last couple of days so I took the bug out for the first time since Friday, and Friday was a case of up in the air, the wind is way to high for this, and down. Today, so far has been OK, I flew it up and just worked on fairly normal flight. I seem to be trending towards less pure anarchy in the sky and more focused flying. The wind is still a bit stiff, a hung the plane several times in the wind motionless. That always amuses me. I'm going to try something a touch different on my next flight. Someone recommended 3/8" surgical tubing, cut at 1/4", for a better propsaver. It was also recommended to me to have 2 propsavers on, if one band breaks, the prop is still attached. The fit is tighter than any other rubber band I have used. I'll tell you later how it flew. Tim OK, the surgical tube prop saver seems to be far superior. I only got one flight on it, but it seems better. More tomorrow. Tim
