FERNDALE AIR FORCE -> RE: LightFlite Bug (4/20/2008 2:54 AM)
Speaking of the radio, WOW. I didn't think I would be able to tell the difference in the air, but I was wrong. The few times I flew the laser 6, I thought it was nice and crisp. Then I got the flash 5 and started using it all the time and got used to it. I guess the processor(s) for the sticks are faster. I feel like I have a better progression through the sticks, if that makes sense. For example the airhog bipe that is making the rounds has 7 steps from 0-full power. The flash might have fifty, the optic feels like 100 or truly proportional. This translates to really crisp turns, and I will have some relearning to do. The bug would not fly at 50% on the flash, I needed to have closer to 60% to just sort of float it along. Now I can just float with barely steerage power, at 50%, right where it's supposed to. While a fancy radio won't automatically make you a superstar pilot or make a newby a practiced pilot, it will help tremendously in flying the plane as designed. I am truly impressed with the Optic 6. OK, I cut that from a post on the B.O.C. thread, but the difference is quite noticable. I thought the flash 5 computer radio was great, and it is a good radio, but the difference is quite noticable. Similar to the dx6 radios i'm sure. And I have yet to figure out the advanced mixing[:)], or to couple the right slider to the elevator trim, or even more trick mix the ele with the throttle, so that as I increase power the ele lowers a little to maintain even flight.[X(][8D] Battery 4 is ready and 5 is charging. I did not get my second charger this week, hopefully it will be at the PO on Monday. Tim
