WILL SOMEONE EXAMINE MY LAMA V4    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> RC Helicopter Beginners Forum >> WILL SOMEONE EXAMINE MY LAMA V4
Page: [1]
Login
WILL SOMEONE EXAMINE MY LAMA V4 - 1/16/2008 11:05 AM
Maldrad
Score: 100
Last Login: 2/10/2008
Status: offline
I got my Lama v4 on Friday and I still haven't gotten it off the ground. It keeps tearing my blades up and throwing my flybar off. I took some pictures and put them in their own photobucket account. Will someone please look to make sure everything looks right? Also I took some pictures of the controller to make sure I have everything right on there. Also is there a guide on the net on how to install all the xtreme parts or do they come with instructions? Also do the blades for the Blade CX2 work on the Lama v4? Thank you all for being so patient with me. Link: http://s262.photobucket.com/albums/ii84/Rchelirookie/
Hide Signatures
       Post #: 1
RE: WILL SOMEONE EXAMINE MY LAMA V4 - 1/16/2008 3:52 PM
Maldrad
Score: 100
Status: offline
Alright I just uploaded 11 new pics. Hopefully something will reveal itself. http://s262.photobucket.com/albums/ii84/Rchelirookie/
Hide Signatures
(in reply to Maldrad)
       Post #: 2
RE: WILL SOMEONE EXAMINE MY LAMA V4 - 1/16/2008 7:20 PM
OldScaleGuy
Score: 120
Last Login: 5/25/2013
Status: offline
I looked at the first group. While not a heli expert by a long shot, I have had a V4 for several months. I could not spot any thing wrong. Hopefully some one else can. Are the blades too tight or too loose? They should pivot about the mounting screw freely but not sloppy loose either.
_____________________________
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
       Post #: 3
RE: WILL SOMEONE EXAMINE MY LAMA V4 - 1/16/2008 8:03 PM
SuperBee364
Score: 100
Last Login: 2/3/2012
Status: offline
I have a Lama V4, too. I couldn't see anything wrong in the pictures. I'm not sure what you mean that it's tearing up the blades, though. Is it acting like a bearing isn't turning correctly? When you take the fuselage off, is the swashplate level when the controls and trim are in neutral position? Do the servos move the swashplate in the correct direction when you make control movements on the transmitter? Do the blades turn freely when you add throttle?
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 4
RE: WILL SOMEONE EXAMINE MY LAMA V4 - 1/16/2008 11:20 PM
Jetskeeter
Score: 100
Last Login: 5/21/2008
Status: offline
Hi, remove the fuselage and check the movement of the swashplate. If you move the right stick on the transmitter forward the swash should tilt down, backwards the swash should tilt back, to the left the swash should tilt left and to the right the swash should tilt right. check the blade rotation also. the bottom blades turn cw and the top ccw. If they turn wrong direction you gotta reverse the rotatation by reversing the polarity of the connector plugged into the 4 in 1 by turning it around. If this is all ok , with the transmitter turned on and all the trims centered except the throttle trim , it should be all the way down, now look at the swashplate. It needs to be level. If it is not ,you level it by lengthening or shortening the rods by popping them off the swash and turning them to make them longer or shorter. you should be able to hover it now and stabilize it using the trims.
Hide Signatures
(in reply to SuperBee364)
       Post #: 5
RE: WILL SOMEONE EXAMINE MY LAMA V4 - 1/18/2008 3:28 AM
sblinder
Score: 100
Last Login: 9/10/2011
Status: offline
Hello
I sell the Lama, we test them all before we send them out, I must say I have had 9 in the past two weeks exhibit this same behavior and after
removing the 4 in 1 and replacing it with a spare I had the problems went away. I think there is a lot number out there of Lama's that have bad
receivers, plain and simple. I would be happy to examine your copter for you, even fix it for just the cost of the parts. We can be found here
http://www.helicopterheaven.com
Kindest Regards
Steve
Hide Signatures
       Post #: 6
RE: WILL SOMEONE EXAMINE MY LAMA V4 - 1/18/2008 5:09 AM
RedGN
Score: 135
Last Login: 10/18/2009
Status: offline
can't see what the receiver has to do with the flybar flying off....unless it jerk the throttle violently. The stock inner shaft is cheap plastic where it attaches to the flybar. Change the inner shaft to aluminum one and fly bar will not fly off. also heard a few reports of the swashplate coming apart. you can change this to aluminum also if you like or wait and see if it will happen. I have 3 lama v3 and one v4 with stock swashpaltes and they are fine.
A little more detail next time on what you see or hear or anything that can help rcu members help you.
hope this helps and goodluck
Hide Signatures
(in reply to sblinder)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
