Juice
ON, CANADA Status: online
Hi Len, I had contacted RCV about this project, but not about the suitability of Solo props. The way I understand the issue, wood props are discouraged becuase they are too light and do not provide enough fly-wheel effect. That is why they recommend using heavy wood props (if you really need to use a wood prop). Solo props are made from premium grade eastern maple. Although the blade themselves are lighter than an equivalent size composite prop, the weight of the aluminum hub makes the whole assembly on the heavy side. Actually, the original Solo hub is probably too heavy for a 1/8 warbird. I'm hoping the 1/8 hub will come in at a useable weight. SolidWorks has the ability to calculate weights. I'll give it a try. Josh
