Juice -> RE: 1/8 scale functional Hamilton Standard hub for RCV SP engines. (3/23/2008 2:58:52 PM)
Rick... As 77chickenhawk says... The original Soloprop hub is perfect for 1/5 to 1/6 scale. At 1/7 to 1/8 scale it's to big, which is the reason for this project. I am a computer engineer by trade, but that's the wrong kind of engineer for this kind of stuff. SolidWorks 2008 is the easiest CAD software out there. The nice thing about SolidWorks is that it keeps your attention on the DESIGN, not the DRAWING. AutoCAD and TurboCAD are good DRAWING programs to use after the DESIGN has been finalized. Before this project, I slowly learned to use AutoCAD over the span of 2 or 3 years. I spend on average 1 hour per day working on this project. I started this project using AutoCAD. I spent the first 2 weeks creating a 3D model of the original Soloprop hub. Then I spent another 2 weeks re-designing the 1/8 version. Then I spent a month talking to CNC shops. I spent a couple days in re-drawing for each time they gave me a cost reduction tip. This was when I got fed up and switched to SolidWorks. I did one SolidWorks Tutorial per day for a week. I had everything re-drawn in SolidWorks in anoter week. Then it felt like no effort to draw other stuff like the props, the boss, the bolts. Even redrawing the RCV 90 is SolidWorks was easy, but it was a lot of measuring. If you're designing an engine, then SolidWorks has even more benefits for you. But now I'm starting to sound like a SolidWorks salesman. Josh
