Juice -> RE: 1/8 scale functional Hamilton Standard hub for RCV SP engines. (5/5/2008 5:21:47 AM)
RPM Test #2 Engine: RCV 90SP Fuel: Red Max 10% nitro, 7% caster, 14% total oil content. 1) MAS 18x12x2 5280 RPM 2) APC 15.75x13x3, 5300 RPM 3) 1/8 Hub 18x13x3, 3840 RPM 4) 1/8 Hub 18x11x3, 4400 RPM 5) 1/8 Hub 18x10x3, 4450 RPM 6) 1/8 Hub 16x13x3, 4760 RPM 7) 1/8 Hub 16x12x3, 4960 RPM 8) 1/8 Hub 16x11x3, 5200 RPM The extra 4 oz of the hub does have an negative effect on max RPM. And I had hoped that I can fly with the 18" props. But from these RPM numbers the 90SP doesn't have enough to spin it above 5000 RPM. It looks like I'll be flying with the 16" blades set to 11" pitch. I hope to make the flight on either Thursday night or sometime next weekend. I may also buy different fuel next time also. I actually don't like the Red Max fuel I used for this RPM test, because both of my RCV engines could never idle well with it. I had been using a special fuel mix prepared by a gentleman named Otto Kudrna, who used to be the RCV Customer Service rep for North America a couple years ago (I can't find him anywhere now). His fuel was the best. I still have a few quarts of the RedMax fuel, but I don't feel comfortable flying with it. Josh Josh
