snurckle -> RE: 1/8 scale functional Hamilton Standard hub for RCV SP engines. (5/9/2008 12:30:31 AM)
Scalecraft - good to know, just means I have to be more careful. All who have built the TF 1/8th scale Corsair - What is the distance from the Prop nut to the ground when the plane is level - and not on the tailwheel? Just curious whether an 18" blade will be too big for the plane, or if I should consider the RCV 90 with a 16" prop. I'm currently building a list of all the mods I have seen on the corsair, and when I get home (on Saturday), I'm going to go through the manual with a fine tooth comb, and put stickies in it, showing where I need to consult the mods. The kit arrived at home today, the wife was sure to let me know- conversation went something like - "What the h!@#, yada yada yada" I tuned out after the h@#$, and simply said "So, I take it the plane arrived in the mail". -That didn't go over so well. I'm away TAD/TDY right now, but will be able to get to work on it Saturday....after I build the table to build the kit. I'll probably still put the RCV120 in it....not like I have to decide any time soon, but I have allocated the funds for the hub, so I'm definately tied in to one of the two engines.
