HS-81 servo horn screw size
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HS-81 servo horn screw size
Page: [1]
Login
HS-81 servo horn screw size - 1/17/2008 2:41:35 AM
BobWoodhouse
Status: offline
What is the spec/size of a HS-81 servo horn screw?
Best,
Bob
       Post #: 1
RE: HS-81 servo horn screw size - 1/17/2008 3:37:45 AM
A.T.
Status: offline
quote:
ORIGINAL: BobWoodhouse What is the spec/size of a HS-81 servo horn screw? Best, Bob
Screw for resin geared HS-81 = 2.2mm x 5mm as per:
Hitec Screw Set for Resin Geared Servos
In case you also have HS-81MG, the following may assist.
Hitec Screw Set for Metal Geared Servos #55802 "Metal servo Screw Set (5 x short, 5 x long)".
Standard Servo Screws (Metal Gear Servos) 2.6mm x 6 mm & 8 mm to fit
HS-225MG, HS-525MG, HS-625MG, HS-645MG, HS-705MG, HS-925MG, HS-945MG, HS-5245MG, HS5625MG, HS-5645MG, HS-5745MG, HS-5925MG, HS-5945MG, HS-5955TG, HS-5995TG, HS-5996TG, HS-5997TG, HS-5998TG.
The small screws [Five 2.2 x 5 mm Phillip-head screws] fit the HS-65MG, HS-81MG, HS-85MG, HS-125MG.
NB: Never use loctite. In need if star washer is lost, Liquid Thread Lock may be used sparingly and ensure none remains in contact with plastic parts.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(in reply to BobWoodhouse)
       Post #: 2
RE: HS-81 servo horn screw size - 1/17/2008 5:39:03 PM
MikeMayberry
Status: offline
It's actually 2.3mm not 2.2mm.
Mike.
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to A.T.)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.203RCU1
