UPDATED -- Futaba 6EX and 7C Serivce Advisory
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> UPDATED -- Futaba 6EX and 7C Serivce Advisory
Page: [1] 2   next >   >>
Login
UPDATED -- Futaba 6EX and 7C Serivce Advisory - 1/17/2008 2:42:28 PM
Krysta
Status: online
Futaba 6EX, 7C and TM-7 Service Advisory- Updated 01/30/08
This service advisory affects only owners of the Futaba TM-7 module and 6EX and 7C FASST systems. Each FASST transmitter contains a unique eight digit identification code, programmed at the factory to identify the respective transmitter and to allow a receiver to be paired only to that radio’s signal. Recently we have learned that a very small number of the TM-7 modules, and 6EX and 7C FASST systems were incorrectly coded with a common code number during the manufacturing process. These units were subsequently sold prior to our awareness of the situation.
If two or more units, utilizing this common identification code, were to be in use simultaneously, they may cause interference with one another. Please note: Units which utilize the correct identification code will not be affected by these units.
We’re extremely confident that this is not a widespread problem. However, to catch any possible incorrectly coded units in the field and to give you peace of mind that your system is not affected, we have set up test stations at participating hobby shops throughout the country where you will be able to determine -- within a matter of minutes -- whether or not your transmitter is affected, at no charge to you. There are 100 such Test Stations in place now, and the number will be increased to 500 over the next two to three weeks. Please see: http://2.4gigahertz.com/techsupport/service-advisory-tm7-7c-6ex.html#list for a listing of these testing stations. Or, if you prefer, you may send it in to our service center and we will analyze it for you at no charge. If any problem is found, it will be replaced. We will gladly pay the postage for returning the unit and sending it back to you.
If you have questions or concerns, please do not hesitate to contact our Futaba Service Center at: 217-398-0007 or via email at: service@futaba-rc.com. Our staff is available to you Monday-Friday, 8am-5pm U.S. Central Standard Time.
Precautionary Measures and Information-
It is important to note that the precautionary measures are relevant only to the Futaba FASST items with serial numbers as described below. To determine if your transmitter might be affected, look on the bottom of the transmitter case. If using the TM-7 module, the serial number is located on the inside portion of the module:
6EX: A7xxxxxxx without the “I” (Inspected) sticker
7C 07xxxxxxx without the “I” (Inspected) sticker
TM-7 07xxxxxx without the “I” (Inspected) sticker
The precautionary measures do not apply to systems that utilize a serial number as noted below:
6EX ALL A8xxxxxxx or systems with the A7xxxxxxx serial number which include the “I” (Inspected) sticker
7C ALL 08xxxxxxx or systems with the 07xxxxxxx which include the “I” (Inspected) sticker
TM-7 ALL 08xxxxxx or modules with the 07xxxxxx which include the “I” (Inspected) sticker
1) As with all radio control equipment, we strongly suggest that you pre-flight your aircraft thoroughly prior to flying. When flying at a location with other FASST owners, prior to flying we suggest that all pilots briefly activate their systems simultaneously to check for any interaction between units. If any interactions should occur, do NOT fly. Return the unit to the Futaba Service Center for immediate replacement.
2) Each time that your transmitter is turned on, it is imperative that you allow the FASST system an adequate amount of time to thoroughly boot-up completely before shutting down the transmitter. After the battery voltage appears on the LCD, we recommend allowing the system to remain on at least one (1) additional second prior to turning off the power to the transmitter.
3) If the transmitter and receiver have lost their binding which required them to be re-linked, we recommend returning them to the Futaba Service Center for analysis. This is not expected behavior and should be investigated accordingly.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
< Message edited by Krysta -- 1/30/2008 7:27:01 PM >
       Post #: 1
RE: Futaba 6EX and 7C Serivce Advisory - 1/17/2008 3:47:26 PM
Teachu2
Status: offline
THANK YOU for getting this posted!
_____________________________
Trent Combs
Fly 'em until the last piece stops!
(in reply to Krysta)
       Post #: 2
RE: Futaba 6EX and 7C Serivce Advisory - 1/17/2008 7:54:21 PM
carlosponti
Status: offline
I am glad to hear futaba is taking care of this. So far i havent had problems with my 7c but i am glad to know ahead of time if there is a problem so i can be cautious.
thanks futaba
joe
(in reply to Teachu2)
       Post #: 3
RE: Futaba 6EX and 7C Serivce Advisory - 1/17/2008 9:51:34 PM
AIRPLANENUTS
Status: offline
I can't resist. This is taken from Futaba's website.
Futaba gets it right the first time.
Futaba takes great pride in making sure that every new product performs flawlessly before it's offered to our customers. Others hesitate to invest so much effort in testing. Some may even consider their "first run" products a step in the process of working out bugs, using feedback from the earliest buyers. Futaba is different. When you choose a Futaba 2.4GHz FASST radio system or module/receiver set, you've selected a fully tested, well-engineered, totally reliable product – one that's absolutely ready to give demanding R/C hobbyists the performance they expect. Our hands-on experience with 2.4GHz technology stretches back 15 years, long before anyone considered its value in hobby applications. That's when engineers in Futaba's industrial R/C division – designers of radio-control tools for construction, civil engineering, and similar uses – began employing and perfecting their own 2.4GHz equipment. Those same engineers were brought in to share their knowledge as soon as we were comfortable that 2.4GHz technology had perfected for the unique demands of R/C hobby applications. No other radio manufacturer had such an instant supply of expertise.
"Futaba gets it right the first time."
(in reply to carlosponti)
       Post #: 4
RE: Futaba 6EX and 7C Serivce Advisory - 1/17/2008 10:01:18 PM
shakes268
Status: offline
quote:
ORIGINAL: AIRPLANENUTS
Your glee in the troubles of others would be noteworthy had your post presented something new. However, you were beaten to the punch in other threads - numerous times.
(in reply to AIRPLANENUTS)
       Post #: 5
RE: Futaba 6EX and 7C Serivce Advisory - 1/17/2008 10:12:37 PM
Teachu2
Status: offline
Make something foolproof, and there evolves a more advanced fool..................
Trent Combs
(in reply to shakes268)
       Post #: 6
RE: Futaba 6EX and 7C Serivce Advisory - 1/17/2008 11:16:21 PM
harphunt
Status: offline
I am happy to finally see that this issue has been addressed by Futaba. I am still unsure about the "Switch" issue. If my 7c "checks out," it seems that tx can reset its code by being switched on and off at "incorrect" intervals. I'm confussed then. Is this correct?
Krysta, please respond to this post-manufacturing issue.
       Post #: 7
RE: Futaba 6EX and 7C Serivce Advisory - 1/18/2008 5:58:21 PM
Krysta
Status: online
Hi harphunt,
The chances of someone being able to cycle the transmitter power off and on in 3 milliseconds would be highly doubtful. This is a precautionary statement only. It has not been confirmed by Futaba. As long as you give the transmitter time to power off, when shutting down, you should not have any problems.
Just as on your home PC, it is not good to just pull the plug from the wall when you are done, you actually turn it off step by step to let the PC itself, shut each function down. This is the same concept for your transmitter, and this is a good precaution with ANY computer radio.
Also if you never have had to rebind your receiver to your transmitter, then your system is not zeroed out and it is fine.
Sincerely,
Krysta
< Message edited by Krysta -- 1/18/2008 8:35:23 PM >
(in reply to harphunt)
       Post #: 8
RE: Futaba 6EX and 7C Serivce Advisory - 1/18/2008 9:13:43 PM
rg
Status: offline
I just tested 3 of my TM-7 modules to see if they would connect to two new unbound 607 rx's and one module connected to both receivers, the other modules will not connect, I think I have a module with a zero GUID, and I think I have been lucky as this is the only module I have flown with yet!!!! Sorry should have added I purchased all 3 modules in the US and I am wondering where do I stand with regard to warranty.
< Message edited by rg -- 1/18/2008 9:18:01 PM >
       Post #: 9
RE: Futaba 6EX and 7C Serivce Advisory - 1/18/2008 9:18:28 PM
Silent-AV8R
Status: offline
Well, you would have only had a problem if another zero GUID TX showed up. An non-zero TX would not control your RX's that were bound to non-zero GUID TXs already.
For grins, take one of the RXs you used for this test and actually go through the binding process with the module you suspect of being a problem. Then repeat the test. I am curious what happens in this instance.
Reality is Subjective. At least that's what I think.
(in reply to rg)
       Post #: 10
RE: Futaba 6EX and 7C Serivce Advisory - 1/18/2008 9:34:32 PM
rg
Status: offline
I don't think this will make any difference as I was prompted to check all my moduleswhen the service advisory stated that there is a problem if you had to re-bind which I had to do once with this module
(in reply to Silent-AV8R)
       Post #: 11
RE: Futaba 6EX and 7C Serivce Advisory - 1/19/2008 12:47:23 AM
cwharper
Status: offline
I bought my 6EX FASST back in May 2007. Is there any chance that mine was affected? I've never had any problems, and never had to rebind any receivers (I have 5 rx)
When you see the mushroom cloud, you will know then that I have finally achieved fusion.
(in reply to rg)
       Post #: 12
RE: Futaba 6EX and 7C Serivce Advisory - 1/19/2008 1:06:10 AM
shaggman1
Status: offline
Can someone clarify if this is a Tx or Rx problem? I'm wanting to know about the problem this thread was created to explain. If I read that first post right Krysta is warning of a possible Tx issue.
Also Krysta, is there a page we can go to see when and where the testing at local shops will be available?
Sam
(in reply to cwharper)
       Post #: 13
RE: Futaba 6EX and 7C Serivce Advisory - 1/19/2008 5:00:45 AM
Rudy F
Status: offline
quote:
ORIGINAL: Krysta
Hi harphunt,
Sincerely,
Krysta
What quality is the power switch? Double contacts? Goldplated?
