dwbebens
TN, USA Status: offline
speedster 1919 Actually, the TT GP 42 IS a .42! The Tower, Ace, and other reseller sites are wrong. The official Thunder Tiger site http://www.tiger.com.tw/product/9041.html lists the displacement as a .421 . See the data below that I cut-and-pasted directly from their site: Description GP-42 Item No 9041 Category Engine >>> Nitro Engine >>> 2-Stroke Aircraft GP Series Update Data 2008-04-08 Displacement 6.90 c.c. / .421 cu.in. Bore 21.5 mm / 0.846 in. Stroke 19.0 mm / 0.748 in. Practical R.P.M. 2,000 ~ 15,000 rpm Output (BHP/RPM) 1.10 / 14,000 Weight (g/oz) 357.2 / 12.60 To absolutely clear up this issue, I went out and re-measured my TT GP 42. I had done this in the past in response to this same issue in a former forum post. bore = 0.845" and stroke = 0.749" - - within 0.001" in each case from the factory specs. As you can verify: Pi*((0.845/2)^2)*0.749 = 0.420 cu. in. It baffles me that all the re-sellers of this engine give the wrong bore, stroke, and displacement for this engine. It IS a .42. That's probably why it is almost as good as the TT Pro 40. In our Club 40 races here in Nashville, when a well flown TT GP 42 is flown against a well flown TT Pro 40, the finishing difference is only about 1/4 to 1/2 lap at the end of 10 laps. For local preference reasons, we allow the TT GP 42 in both Novice class and Advance class, that's why there were 42's in our advanced class. Doug Bebensee
< Message edited by dwbebens -- 4/25/2008 4:50:36 PM >
