RE: JHH F86
Tower Hobbies
Logged in as Guest
  Printable Version
BVM Super Bandit/Simjet 2300 with jet case - RTF
Seller:  Erik R
Details:   $6,000.00   |  10/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: JHH F86
Page: <<   < prev  1 [2] 3 4 5 6 7 8   next >   >>
Login
RE: JHH F86 - 1/22/2008 12:30:40 PM
F-16 Skywalker
Status: offline
Ive got some Robart mains that are to large in profile to use with the JHH F86
what should and/or can be used on this bird?
Thanks in advane:Chuck
_____________________________
Yellow Aircraft F-16 / JR - - - - JHH F-86 / Futaba
(in reply to mikedenilin)
       Post #: 26
RE: JHH F86 - 1/22/2008 4:26:53 PM
DaFatha
Status: offline
Skywalker,
The airplane requires low profile mains and a belly mount nose gear. We can provide a set of JHH HD gear if you need a source; please contact us directly.
Regards,
Larry Wolfe
(in reply to F-16 Skywalker)
       Post #: 27
RE: JHH F86 - 1/22/2008 4:45:54 PM
R_Belluomini
Status: offline
Larry,
It's good to see you participate in the forum.
Looking forward to the release of the Fury ARF.
A sweet flying model now with the convenience of an ARF.
Bob
"LUCKY" Electro Bob
(in reply to DaFatha)
       Post #: 28
RE: JHH F86 - 1/25/2008 11:57:26 AM
F-16 Skywalker
Status: offline
Tracking with UPS and is on time in transit, will be here sometime today,(WooooWhoooo!!!!)
(in reply to R_Belluomini)
       Post #: 29
RE: JHH F86 - 1/26/2008 12:33:15 AM
F-16 Skywalker
Status: offline
F-86 came in today (UPS SUCKS!!!)
cracked up the fuse. i'll upload pics later.
cutting out the wood parts right now.
       Post #: 30
RE: JHH F86 - 1/26/2008 4:03:05 AM
F-16 Skywalker
Status: offline
pictures of cracked F86 ,What part of (handle with care/fragile/do not crush)does UPS doesnt understand.(Ediots I tell ya)
I will start a build thread with this thread.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 31
RE: JHH F86 - 1/26/2008 4:05:36 AM
F-16 Skywalker
Status: offline
Some of the cracks in the canopy area is ok cuz it gets cut out anyway.
viojett/KBV72 for power.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 32
RE: JHH F86 - 1/26/2008 6:16:45 AM
F-16 Skywalker
Status: offline
Broke out the Ryobi bansaw(gotta mess to clean up before the wife see it
Cut out the Balsa and Plywood parts.
in the last picture is of the aft part of the plans,nowhere on it does it detail anything
about the thrust tube,should there be a plywood ring close the the outlet to hold the thrust tube?
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 33
RE: JHH F86 - 1/26/2008 1:24:50 PM
Jetpilot24
Status: offline
quote:
ORIGINAL: F-16 Skywalker
Your cracks in the fuse can easly be repaired. Use some thin C/A on them then onthe in side sand them with 80 grit sand paper and clean the aera with laquere thinner. this goes for any aera you will be epoxying in formers too. Use some strips of 3/4 oz fiberglass cloth. Get yourself some Finish cure epoxy from Zap. Mix it 50/50 and brush it on the inside of the fuse where the crack is then lay in your strip of fiberglass. Have you glass cut before hand. An easy way to cut the glass is to go to your local fabric store i.e. joan fabric and pick up a fabric cutting wheel.
< Message edited by Jetpilot24 -- 1/26/2008 1:32:10 PM >
       Post #: 34
RE: JHH F86 - 1/26/2008 1:30:49 PM
Jetpilot24
Status: offline
The thrust tube fits flush to the fuse. It will also be cut to form to the over hang at the tail. One thing you might want to do is put a 1/2 bulk head ring in the tail to tie the vertical fin and horizontal fins togeather. The fuse in this aera will have some flex left and right viewed from the back forward. The 1/2 ring will stiffen this up. Also you wight want to consider a 1/8th inch ply spare about 2 to 3 inches up into the vertical fin and tied into the 1/2 ring.
       Post #: 35
RE: JHH F86 - 1/27/2008 12:56:32 PM
F-16 Skywalker
Status: offline
Ok i see, the thrust tube is like my yellow F16.
still working more build pic to come.
Lets take a pole on a paint scheme.
(in reply to Jetpilot24)
       Post #: 36
RE: JHH F86 - 1/27/2008 5:07:21 PM
jescardin
Status: offline
F-16 Skywalker with that powerplant be ready for "ballistic" performance but also watch the flying time for avoiding dead-stick landings. Also remember to improve the fan tail cone fairing if you do not want it to be "blowt-out" from the tail when you speed up the engine as I suffered with my Maverick till simply I removed it.
Best luck with the building and flying.
Best Regards,
Jesus Cardin
       Post #: 37
RE: JHH F86 - 1/27/2008 5:36:27 PM
Jetpilot24
Status: offline
Other than mine, this is one I would do if I was doing another F-86
Click for fullsize
Click for fullsize
