RE: JHH F86
Tower Hobbies
Logged in as Guest
Users viewing this topic: iflyg450
  Printable Version
The JETLEGEND L-39 (3 COLOR SCHEMES) We now offer building & Special Paint scheme
Seller:  FlyingboyD
Details:   $2,600.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: JHH F86
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: JHH F86 - 2/13/2008 10:17:21 PM
Jetpilot24
Status: offline
quote:
ORIGINAL: F-16 Skywalker
Im glassing over balsa sheet, sheeting technic was with wing sheeting contact cement,
skins was not glued together at the joints so i was looking for foam safe thinner just incase
some seepage through while glassing.
Do your self a favor and save the weight. just monocote the wing. I did mine this way and total weight on the plane was 9 pounds. you will add about an extra pound of weight with fiberglass.
(in reply to F-16 Skywalker)
       Post #: 51
RE: JHH F86 - 2/13/2008 10:33:21 PM
MMallory
Status: offline
Not true, mine is right at 9 lbs. It is glassed and painted in 2 part PPG with 2 coats of clear. Just don't go crazy with the resin.
(in reply to Jetpilot24)
       Post #: 52
RE: JHH F86 - 2/13/2008 11:22:53 PM
F-16 Skywalker
Status: offline
im using 3/4oz fiberglass cloth with pacer Z-Poxy
_____________________________
Yellow Aircraft F-16 / JR - - - - JHH F-86 / Futaba
(in reply to MMallory)
       Post #: 53
RE: JHH F86 - 2/15/2008 3:05:59 PM
Mark 5
Status: offline
Hello Mark,your F-86 is a beauty.I remember when you flew it at Floyd Bennett. What a sweet flying airplane.Your F-86 is just screaming Wren 44.
Mark
       Post #: 54
RE: JHH F86 - 2/15/2008 3:10:29 PM
MMallory
Status: offline
Mark,
I wish my bank account was screaming Wren 44. As long as the K&B .48 stays in one piece, I think this plane will remain ICDF. BTW, it went out for a few sorties this past summer and will be out again this year.
Mark
(in reply to Mark 5)
       Post #: 55
RE: JHH F86 - 2/22/2008 5:20:28 AM
F-16 Skywalker
Status: offline
Work and my 11 month old baby girl keeps me pretty busy but i did manage to get a bit more done
on this bird.
pic are mocked up nothing glued, although i do think the anhiederal looks somewhat cool.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 56
RE: JHH F86 - 2/22/2008 5:23:49 AM
F-16 Skywalker
Status: offline
What a mess im into now..lol..
more progress pics.cut out the canopy, thinking of making up a extra former in a cicular pattern to
stiffin up the aft part of the canopy cut out.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by F-16 Skywalker -- 2/22/2008 5:32:07 AM >
       Post #: 57
RE: JHH F86 - 2/22/2008 5:30:16 AM
F-16 Skywalker
Status: offline
Fiberglassed the wing root joint for extra strenght and cut out the flaps,alerons and glued wingtips in place.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 58
RE: JHH F86 - 2/22/2008 5:41:12 AM
F-16 Skywalker
Status: offline
Question about the wing fence, is this an absolute, i see f86's from several manufacturers and some have em and some don't , will this bird slow down enough to need them ?
       Post #: 59
RE: JHH F86 - 2/22/2008 4:22:38 PM
YellowAircraft
Status: offline
Hi,
I've built two of these over the years. You could say I cut my builder's teeth on it. The thing about that little plane is that you could build it as simply as you wanted to, or you could hang a bunch of scale ecoutrements on it and it would still fly beautifully. Dorian Anderson built and flew some beautiful ones. They offer an ARF now, but building one yourself from a kit is fun and character-building!
Yellow Aircraft, JetCat Engines, Skymaster ARF+ and Turn Key Jets
www.cyctheatre.com
       Post #: 60
RE: JHH F86 - 2/23/2008 11:35:52 PM
F-16 Skywalker
Status: offline
My wing dehiedrel is off a bit, cant tell just by the eye but if i place it on a flat surface i can tell, not much just a tab, im wondering what this will cause in flight,.
Hi Sean, where can i get a missle rail for my older yellow F-16 ? i assume it doesnt matter old or new.
(in reply to YellowAircraft)
       Post #: 61
RE: JHH F86 - 2/24/2008 2:01:49 AM
YellowAircraft
Status: offline
Hi,
No, it doesn't matter. We got 'em. You only need one?
www.cyctheatre.com
       Post #: 62
RE: JHH F86 - 2/24/2008 12:50:11 PM
F-16 Skywalker
Status: offline
Yes I need one. Thanks:Chuck
       Post #: 63
RE: JHH F86 - 2/25/2008 4:46:03 AM
F-16 Skywalker
Status: offline
Virtical and horizontil stabs already glassed, prepairing to glass wing,flaps and alerons
Click for fullsize
Click for fullsize
