alcarafa
FL, USA Status: offline
CHECKMATE THE ONE ON THAT THREAD IS A 90 - 120 SIZE ENGINE YAK, THIS THREAD IS ABOUT 60 SIZE ENGINES YAK. CARLOS IT SEEMS LIKE JUST TWO PERSONS HAVE BOUGHT THIS PLANE SO FAR, HAVE YOU FLOWN YOURS YET?. IF NOT LETS SHARE OUR EXPERIENCES HERE, HOW ABOUT THAT ? IM CONCERNED ABOUT CENTER OF GRAVITY, I'VE READ ON THE OTHER YAK 54 THREAD THAT CG IS NOT CORRECT AS STATED IN MANUAL, FOR THIS PLANE BALANCING AS PER MANUAL STATES IS: 6.5 - 7.5 CM (650MM - 750 MM) BACK FROM LEADING EDGE OF THE WING, MEASURED AT WING TIP, AND FOR WHAT I UNDERSTOOD ON THE OTHER THREAD IT SHOULD BE MEASURED FROM WING ROOT.
