Lou Crane
Joined: 5/11/2006 From: Sierra Vista, AZ, USA Status: offline
I've threatened to go through a "full range check" at any RC field that requires it before flight: Clothespin on board with " 2 x 0.015 x 60' "...(or whatever...) Connect the lines: Make like pulling the throttle lever on a Roberts' type 3-line handle and holler "Throttle... Check!" Wave the handle left and right, and call out, "Rudder... Check!" Twist the handle clockwise and counterclockwise on an axis through my forearm, and call out, "Aileron... Check!" Move the handle up and down, and call out "Elevator...Check!" If I get that far with this, no one can say I DIDN'T do the required range check. I expect some past, and potentially future returning, ukies would start laughing and destroy the mood...
_____________________________
\BEST\LOU Lou Crane, Sierra Vista, AZ
