HeloHurtz
TX, USA Status: offline
quote:
ORIGINAL: Missileman Connection break can also be a polarity problem with the balance connector. Hmmm, the battery seemed to charge on my stocker charger but truth be told, the charge doesn't last long. Regards polarity in general, the umbilicle cord between the BC6 and the ALIGN card consists of 8 wires, 6 red and 2 black. I've taken a closer look at the connector of the cord and cant see that it makes a differnce regard the black pair being installed as pins 1-2 or pins 7-8. Regardless, I've tried both. quote:
ORIGINAL: Missileman Mine came with 2 boards, one for Thunder Power and one for whatever most other batteries use, including E-Sky. The 2 boards each had there own cable to connect to the charger, the polarity is opposite on each cable and if I used the wrong one I would get connection break error. I'm using the 'other' that I believe is called ALIGN... Its what I ordered and I confirmed it to be the plug based on a battery lookup site.
_____________________________
(the pilot walked away from the heli pictured in my avatar)
