kahloq
CO, USA Status: offline
quote:
ORIGINAL: Luxuswaffe As I predicted the greatest disadvantage are the retracts. Although mine would retract on standing, the airflow prevent mine from retracting. I am running on a 6V receiver battery. Also, the mechanical retracts became wobbly but will withstand the landing forces. I am working on a air retracts solution. What retract servo were you using? If you put in a Jr 791, the wind will not be a problem at all. Its got 260oz of torque on 4.8v. However, since your running a 6v rx battery, you'd either need to run a voltage regulator inbetween the servo and the rx, or run a separate 4.8v battery for the jr791 as they will not function on 6v. Also, if using a futaba tx/rx, you would need the voltage regulator as there is a cross-link problem between the futaba rx and the jr 791 even when using a 4.8v battery. If the voltage reads above 5.4v the 791 servo will not operate. This issue is not present when using a JR or Spektrum compatible radio/rx
