2 plugs are better than one?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 plugs are better than one?
Page: [1]
Login
2 plugs are better than one? - 1/19/2008 10:29:49 PM
geminitool
Status: offline
I have a big glow engine and what i have done is machine a cylinder head with 3 glow plugs. Has anyone done this? pros/cons.
The engine runs great. no loading up runs on any fuel and very relible. It made that sloppy midrange run like it has an after burner. Im running a 20 x 8 prop
       Post #: 1
RE: 2 plugs are better than one? - 1/19/2008 11:21:26 PM
jessiej
Status: offline
Interesting. I an aware of several engines that have been manufactured in the past with dual plugs but nine with three.
What kind of engine is it?
jess
(in reply to geminitool)
       Post #: 2
RE: 2 plugs are better than one? - 1/19/2008 11:26:09 PM
Flyer95
Status: offline
Thats why I like the OS-F glow plug so much for any twostroke engine bigger than a 91. The plug clears the midrange and makes it easy to set the needles rich for a nice thick smoke trail Maybe 2 or 3 glow plugs have effects in the same direction as one really hot glow plug or maybe even better? Have you gained any top rpm compared to a single plug operation?
       Post #: 3
RE: 2 plugs are better than one? - 1/20/2008 12:25:13 AM
MOTORMAN37
Status: online
I have seen many Giant scale air racing glow engines where they had more than two glowplugs. But these were some pretty big glow engines. 200 CC quadra's all the way up to 280CC modded Herbransons. Were taling about 40 HP with these.
(in reply to Flyer95)
       Post #: 4
RE: 2 plugs are better than one? - 1/20/2008 12:28:21 AM
Hobbsy
Status: offline
Why not tell us the engine make, size of engine, fuel used and top rpm plus idle speed.
_____________________________
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 5
RE: 2 plugs are better than one? - 1/20/2008 1:25:45 AM
geminitool
Status: offline
Its hard to check rpm because my tach is a glow bee (junk) dart board would work better. as for the fuel i used 0-10 nitro wild cat. I have tried all kinds of plugs but this set up work great. It seem all engines from 1.2 or bigger would be so easy to break in and no flame out.
(in reply to Hobbsy)
       Post #: 6
RE: 2 plugs are better than one? - 1/20/2008 3:19:38 AM
wjvail
Status: offline
http://runryder.com/helicopter/t299358p1/
I think there is a point of diminishing returns to adding plugs but more than one seems to be an improvement.
Bill
www.RCScreenProtectors.com
"Well, Nothing bad can happen now."
       Post #: 7
RE: 2 plugs are better than one? - 1/20/2008 12:42:52 PM
Hobbsy
Status: offline
A GloBee will read just fine.
       Post #: 8
RE: 2 plugs are better than one? - 1/20/2008 5:28:09 PM
jessiej
Status: offline
I am still curious as to make and size of the engine, I have a dual plug Fox and a couple of dual plug Mercos, but could never tell any improvement over the single plug variants. They looked neat though.
jess
       Post #: 9
RE: 2 plugs are better than one? - 1/20/2008 5:53:11 PM
Sport_Pilot
Status: offline
quote:
Thats why I like the OS-F glow plug so much for any twostroke engine bigger than a 91. The plug clears the midrange and makes it easy to set the needles rich for a nice thick smoke trail.
That means you are using low nitro fuel and the plug is hotter than it needs to be. When you have the right plug or nitro then the smoke trail will only be thick when accelerating. However, the needles will be harder to set, but you will have more power and or use less fuel.
Having more than one plug increases the timing much as having a hotter plug, some will use a cool and a hot plug but I am not sure of the mechanics of that. Of course it helps with reliablility as it will still run when one plug burns out. They were used on older engines when extra hot plugs were not available, and the ones they did have tend to burn out quicker than today.
< Message edited by Sport_Pilot -- 1/20/2008 5:57:09 PM >
“I Saw Elvis at 1000 Feet” John Force
       Post #: 10
RE: 2 plugs are better than one? - 1/20/2008 5:53:33 PM
geminitool
Status: offline
210 mark.
My globee tach read 12500 with a 20 x 8 I dont believe it . I need a better tach.
I just added the extra plugs to get rid of the sputter and not have a flame out in
my big bipe http://www.youtube.com/watch?v=e0xDTzO39Fs
(in reply to jessiej)
       Post #: 11
RE: 2 plugs are better than one? - 1/20/2008 6:12:34 PM
DarZeelon
Status: online
Gemini,
That would have been over 16 HP....The Moki 2.10 (that's its real name) is a very capable engine, but 3.2-3.5 HP is about what you should get, around 9,000 RPM.
Having several plugs would allow the one that has the leanest mixture in its vicinity to ignite it in every revolution... Less missing is the result, but flame propagation will not be uniform.
I am not sure what that would cause...
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
       Post #: 12
RE: 2 plugs are better than one? - 1/20/2008 9:38:43 PM
Broken Wings
Status: offline
I use a OS H-80 that has dual plugs. Runs great and it has never dead sticked. I've tried using one hot and one cold plug but can't tell the difference. Light either one and the engine runs
It makes me feel better having twin glow plugs............smiles
Regards,
John
(in reply to DarZeelon)
       Post #: 13
RE: 2 plugs are better than one? - 1/20/2008 11:38:21 PM
jessiej
Status: offline
My GloBee generally gives the same readings as my TNC though the TNC is less sensitive to light conditions and will read from further away. For that matter my antique vibra-tac gives about the sane readings too and needs no light at all
jess
       Post #: 14
RE: 2 plugs are better than one? - 1/21/2008 12:03:09 AM
Broken Wings
Status: offline
Vibra-Tach...I remember those.
Regards,
John
