RE: Yak-3, scale 1:6, composite build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Yak-3, scale 1:6, composite build
Page: <<   < prev  1 2 3 4 5 [6] 7 8   next >   >>
Login
RE: Yak-3, scale 1:6, composite build - 2/24/2008 5:10:32 AM
warbird51
Status: offline
Hey, thats looking like the wing I have in the hanger!! Only smaller....
Looking good!!!
(in reply to lz-23)
       Post #: 126
RE: Yak-3, scale 1:6, composite build - 2/24/2008 5:17:31 AM
lz-23
Status: online
Thanks Wayne! I try to do as scale as I can. Almost done here. Intakes will be on separate mold, so I'm not going to work on them now. Have to round leading edge and wingtips. And must be glassed immediately after that, because I use very soft balsa for easy shaping. Pretty much glassing everything is next step.
(in reply to warbird51)
       Post #: 127
RE: Yak-3, scale 1:6, composite build - 2/25/2008 4:47:28 PM
lz-23
Status: online
A little interesting info.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to lz-23)
       Post #: 128
RE: Yak-3, scale 1:6, composite build - 3/7/2008 4:40:32 AM
warbird51
Status: offline
Iz-23
We got the vertical and rudder installed and rigged as well as the elevator. We're going to need the engine soon as we are running out of things to do!!
How is yours coming?
Click for fullsize
Click for fullsize
(in reply to lz-23)
       Post #: 129
RE: Yak-3, scale 1:6, composite build - 3/7/2008 5:36:01 AM
lz-23
Status: online
Well, I was sick last week, some cold or flu or something and didn't move much forward. Basically horizontal stab i ready for molding. Today I receive some fiberglass cloth and epoxy dye. Now is time for glassing the wing and the fuse. Probably this weekend.
Your Bird look awesome! Can't wait to see her completed!
< Message edited by lz-23 -- 3/7/2008 5:38:08 AM >
       Post #: 130
RE: Yak-3, scale 1:6, composite build - 3/7/2008 5:37:35 AM
Evil_Merlin
Status: offline
Glad you are feeling better LZ.
(in reply to lz-23)
       Post #: 131
RE: Yak-3, scale 1:6, composite build - 3/7/2008 5:39:35 AM
lz-23
Status: online
Thanks Evil, not fully recovered, but on my feet, witch is what's counts.
(in reply to Evil_Merlin)
       Post #: 132
RE: Yak-3, scale 1:6, composite build - 3/12/2008 5:08:48 AM
lz-23
Status: online
Slow progress: stabilizer is filled and primed, wing is glassed. Next will be filler on the wing and glass for the fuse.
Click for fullsize
Click for fullsize
(in reply to lz-23)
       Post #: 133
RE: Yak-3, scale 1:6, composite build - 3/18/2008 1:03:45 AM
lz-23
Status: online
Here is the wing, now will be lots of sanding...
Click for fullsize
(in reply to lz-23)
       Post #: 134
RE: Yak-3, scale 1:6, composite build - 3/18/2008 4:22:08 PM
lz-23
Status: online
Wayne, can you help me please? If is possible, take some pics of ailerons of your Yak. I'm getting to them soon. Thanks!
(in reply to lz-23)
       Post #: 135
RE: Yak-3, scale 1:6, composite build - 3/19/2008 7:06:00 AM
warbird51
Status: offline
quote:
ORIGINAL: lz-23
Will do tomorrow.
(in reply to lz-23)
       Post #: 136
RE: Yak-3, scale 1:6, composite build - 3/19/2008 4:18:28 PM
lz-23
Status: online
Thanks a lot! Is not urgent, do it when is possible for you. You are my savior!
       Post #: 137
RE: Yak-3, scale 1:6, composite build - 3/19/2008 5:05:22 PM
Evil_Merlin
Status: offline
Wayne, thanks for being such a sport and helping us hobby types with our mutual passion!
(in reply to lz-23)
       Post #: 138
RE: Yak-3, scale 1:6, composite build - 3/20/2008 3:51:11 AM
warbird51
Status: offline
Here you go. Specs are as follows, Aileron length, 62.25" Aileron cord at the tip 4.75' aileron cord at the tip, 12.75" These dimentions are from the wing opening looking down fron the top as the aileron is longer in cord when viewed from the bottom. There are 9 ribs not counting the end ribs with a rib spacing of 6.22" The trim tab is 10.25" long and 1.125" wide and the inboard end is 8.0" from the inboard end of the aileron. The rib stitching runs fore and aft instead of side to side as typically seen. rib stich spacing is .5" The aileron mounted on the wing has the side stitching which looks bad to me. the aileron not mounted is stitched correctly.
Wayne
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by warbird51 -- 3/20/2008 3:52:29 AM >
(in reply to lz-23)
       Post #: 139
RE: Yak-3, scale 1:6, composite build - 3/20/2008 4:22:02 AM
lz-23
Status: online
Thanks Wayne! I'm in your debt! I really hope, that You will like the final result of my work.
Cheers!
       Post #: 140
