building board material
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> building board material Page: [1] 2   next >   >>
Login
building board material - 1/20/2008 12:35:10 AM
Eddym
Status: offline
All,
What is the best building board material for securing pins.
       Post #: 1
RE: building board material - 1/20/2008 1:06:37 AM
Flyboy Dave
Status: offline
...."soundboard" at the local builders supply. It's a soft fiberboard, painted white on one side.
FBD.
_____________________________
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to Eddym)
       Post #: 2
RE: building board material - 1/20/2008 1:53:43 AM
reincarnate
Status: offline
Agreed. Or plain old lay-in ceiling tiles.
(in reply to Flyboy Dave)
       Post #: 3
RE: building board material - 1/20/2008 3:53:27 PM
Dr1Driver
Status: offline
I use ceiling tiles with a sheet of 3/32" cork laid over that. Perfect!
Dr.1
There's a Hun in the sun!
(in reply to reincarnate)
       Post #: 4
RE: building board material - 1/20/2008 5:17:29 PM
TooLow
Status: offline
the best thing I have found over the years (40) is good ole "drywall"--aka sheetrock. It lays flat over your workbench--stays flat--can be secured with drywall screws--accepts needles and pins--cleans up easy and makes a good reminder pad to write yourself construction notes--oh did I also say its CHEAP!!!
SO MANY KITS--NOT ENOUGH GLUE!
(in reply to Dr1Driver)
       Post #: 5
RE: building board material - 1/22/2008 12:20:40 AM
LunaSea
Status: offline
Homosote.... Comes in 4x8 sheets. Made from recycled newspaper, used for sound deadening in walls. Should be able to find it at your local (larger) builder/lumber supplier. If you use construction adhesive and glue it onto a hollow core door, it makes about a perfect building surface. Use a 24" wide door and get TWO building boards from one sheet. You can never have too many building boards...
(in reply to Eddym)
       Post #: 6
RE: building board material - 1/22/2008 4:42:34 PM
dicknadine
Status: offline
Good old narrow hollow core door. apply layer of ceiling tile - smooth side up- to one side of the door, for pinning balsa to. apply layer of paper to other side and use it for drawing plans on. it's light and can lifted and stored real easy. dick
dick/rcflyer
(in reply to Eddym)
       Post #: 7
RE: building board material - 1/24/2008 3:49:54 AM
Eddym
Status: offline
All,
Thanks for the great replies. I'm glad to see there are a couple options that sound rellatively inexpensive. I will definatly have a new board for my next build.
Eddym
(in reply to dicknadine)
       Post #: 8
RE: building board material - 1/25/2008 1:29:01 PM
dr_wogz
Status: offline
Another one for drywall / sheet rock / gyp rock wall board...
Failure is not an option.
It comes bundled with the software.
(in reply to Eddym)
       Post #: 9
RE: building board material - 1/26/2008 6:15:50 PM
craigteffe
Status: offline
The bad thing about drywall is it will dull the point on your pins and after the first use it is hard to push them in. I use the balsa building boards.
Craig
(in reply to dr_wogz)
       Post #: 10
RE: building board material - 1/29/2008 3:49:25 AM
buzzingb
Status: offline
Dry will also take the chrome finish off T-pins making it harder to push through wood. However, T-pins are cheap.
Buzz
(in reply to craigteffe)
       Post #: 11
RE: building board material - 2/3/2008 2:31:35 AM
Bass1
Status: offline
Sheetrock and plenty of of t-pins. I also have a sewer's "thimble" on hand to protect the finger and drive the stubborn or dull t-pins through the wood, wax paper and plans into the sheetrock.
(in reply to buzzingb)
       Post #: 12
RE: building board material - 4/20/2008 9:41:08 PM
FlyerInOKC
Status: offline
Great Planes makes a nice little T pin tool for T-pins when they get dull. I use drywall and don't buy new T pins until I have bent or loss enough that I run out in the middle of building.
(in reply to Bass1)
       Post #: 13
RE: building board material - 4/21/2008 12:04:18 AM
cyclops2
Status: online
AHH. the joy of blue foam scratch building.
(in reply to FlyerInOKC)
       Post #: 14
RE: building board material - 4/21/2008 3:45:36 AM
digital_trucker
Status: offline
I use 1/2 inch of cork glued to 5/8" masonite. Holds pins nice and tight.
I feel I can speak for 90% of humanity when I say 'durrrr'
Skype digital_trucker
(in reply to cyclops2)
       Post #: 15
RE: building board material - 4/21/2008 5:31:14 AM
combatpigg
Status: offline
You can build without pins if you spread out waxed paper tight and lightly mist it with 3M-77.
Led Zeppelin is NOT "old fogie" music.
(in reply to digital_trucker)
       Post #: 16
RE: building board material - 4/21/2008 2:59:02 PM
FlyerInOKC
Status: offline
Hey digital_trucker, where is the best place to find 1/2" cork? None of the home centers carry it anymore around here. I found some thin stuff (3/32) at a craft store but thats about it.
