rexracer
CT, USA Status: offline
Like most things I do in the machine shop, my plans consisted of a rough sketch on graph paper, some notes, and a rough idea in my head. It took me longer to get the pillow blocks and Thomson rod not to bind than it did to make the whole thing. I have 2 pinch bolts on each end of the bars that hold the rod to the moving plate that holds the engine mount. I ended up only using one bolt on each end because if I used 2, it would slightly bend the bar, and bind. If I had to do it again, I would either bolt the bars to the plate, then bore the holes, or make it out of one piece. It does look cool, though! and works well, even if the "thrust" measuring aspect is a bit of a gimmik.
_____________________________
Club Saito member #173
