Mustang Fever
MI, USA Status: offline
I'm glad you knew that, as I was not familiar with the FP series. I really like the LA engines, as well. Properly adjusted, they refuse to quit. I have a 65LA on an RCM Ugly Stik that is a real champ. I've lost track of how many airplanes it has been on. At least 3, maybe more. Just a couple questions: Your throttle servos look like sub micros, is that the case? 2 or 4oz flex tanks for fuel? I'd like to go the micro/sub micro route on throttles and ailerons, but I got burned once using plastic gear micros on a glow plane. The vibration ate the gears. Ever since I've used the HS81MG (metal gear) on small glow models. They are heavy, tho.
< Message edited by Mustang Fever -- 5/6/2008 8:56:21 PM >
_____________________________
Bob Hunt
