Problems with update to 1.11.07.09
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Problems with update to 1.11.07.09 Page: [1]
Login
Problems with update to 1.11.07.09 - 1/21/2008 2:57:56 AM
pmackenzie
Status: offline
I updated my AFPD.
I am not happy.
Graphics are very choppy. The background moves in jumps, not smoothly.
The camera won't follow the plane up off the top of the screen.
Then if I come back down it leads so the plane does not come back in frame until just before it hits the ground.
The plane looks too small now as well, but the scenery is the same size as before.
Running on a P4 3.2 gig machine,1G ram, NVIDEA 7600 video card.
1920x1200 @ 60 hz
It all worked fine on 1.9.07.11.
Can I run the old patch to go back, or do I have to start over from scratch?
Pat MacKenzie
       Post #: 1
RE: Problems with update to 1.11.07.09 - 1/21/2008 4:05:25 PM
rajul
Status: offline
Hi Pat, which addons do you have? Thanks
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to pmackenzie)
       Post #: 2
RE: Problems with update to 1.11.07.09 - 1/22/2008 2:16:37 AM
pmackenzie
Status: offline
None.
Just the stock AFPD.
I do have a few downloaded models, but no official add ons.
Pat MacKenzie
(in reply to rajul)
       Post #: 3
RE: Problems with update to 1.11.07.09 - 1/22/2008 4:34:21 PM
rajul
Status: offline
Hi Pat, can you check what is the version number printed on your main AFPD disk? Thanks
Mike Marks
RCU Moderator
       Post #: 4
RE: Problems with update to 1.11.07.09 - 1/23/2008 12:33:12 AM
pmackenzie
Status: offline
1.8.0.21
Pat
(in reply to rajul)
       Post #: 5
RE: Problems with update to 1.11.07.09 - 1/23/2008 12:45:22 AM
rajul
Status: offline
Hi Pat, in this case you only need the 1.8.0.25 patch. The 1.11.7.9 patch you installed is not suitable and will require a higher video card performance. You will have to completely uninstall and reinstall your AFPD and apply patch 1.8.0.25 The uninstall/install instructions, and patch can be found here http://www.aerofly.com/www/downloads.html
To save your time in setup, you could backup the "config" folder in the AFPD directory. After you have installed AFPD, just copy back this folder into the AFPD directory
Mike Marks
RCU Moderator
       Post #: 6
RE: Problems with update to 1.11.07.09 - 1/23/2008 1:05:02 AM
pmackenzie
Status: offline
That is what I figured I would end up doing.
I had patched higher than the base before, so I will probably up it to where I was.
The video card I have should be good enough, but perhaps not at the 1920 x 1200 resolution i run?
The video was better with the photo scenery, but I usually use "ForestLake".
Before I "downgrade" i will fly a bit in a photo scenery to see if it was better or worse.
But what is the deal with flying off the top of the screen? That would be a deal killer for me.
Pat MacKenzie
(in reply to rajul)
       Post #: 7
RE: Problems with update to 1.11.07.09 - 1/23/2008 1:25:23 AM
rajul
Status: offline
Hi Pat, you should only use patch 1.11.7.9 if you have addons 3 and/or 4. If you use patch 1.11.7.9 with no addons and/or addon 1 and 2, you will see some issues regardless of your video card
Mike Marks
RCU Moderator
       Post #: 8
RE: Problems with update to 1.11.07.09 - 1/24/2008 8:01:36 PM
hvta53
Status: offline
Hi Mike,
I got the same problem with mr:Pat,The camera fail to follow the airplane and normally cut of at the top of the screen.( If the airplane fly just a little bit high and then I won't able to see it any more) I do have 04 add on disks installed to my pc.again here is the pc spec:
-Hp Media center m7287c
CPU 3mhz.
Graphic card:FORSA Geforce 7900 GTX.
500 plus DRAM.
Controller is Spextrum DX7 .
Up date with new current patch:1.11.07.09
Any Idea? Thanks!
hvta
(in reply to rajul)
       Post #: 9
RE: Problems with update to 1.11.07.09 - 1/25/2008 2:05:53 PM
rajul
Status: offline
Hi hvta, in the flying menu, under view1->viewing options what is your setting for the height dependant vertical camera?
Mike Marks
RCU Moderator
(in reply to hvta53)
       Post #: 10
RE: Problems with update to 1.11.07.09 - 1/25/2008 3:27:19 PM
rayjay3
Status: offline
Hi Pat, I was having the same problem that you are having. I tried to download the Cularis from a disc that I got from my cousin in Germany. It screwed up my whole system, everything was jerky. I tried to delete it without much luck. Then a friend mentioned to go to restore and go back a few months and that got me back to where I was. By the way my favorite plane is the Bucker Jungmeister, did you ever try to fly it? Just for the heck of it try and land it without a bounce, impossible! Rayjay
(in reply to rajul)
       Post #: 11
RE: Problems with update to 1.11.07.09 - 1/26/2008 2:03:03 AM
hvta53
Status: offline
Hi Mike.
Under Fixed viewing position window I have:
-Height dependent vertical camera:100%
-Delay camera: 0%
hvta
(in reply to rayjay3)
       Post #: 12
RE: Problems with update to 1.11.07.09 - 1/26/2008 2:09:24 AM
rajul
Status: offline
hvta, reduce your "height dependant vertical camera" and you should solve your problem. You could try a % between 50 and 100
Mike Marks
RCU Moderator
       Post #: 13
RE: Problems with update to 1.11.07.09 - 1/26/2008 2:27:37 AM
hvta53
Status: offline
Hi Mike,
Yes! When I reduced the height Dependant vertical camera to 50% It's work great".You 're the man".Thanks!
Click to see fullsize image.
Click for fullsize
(in reply to rajul)
       Post #: 14
RE: Problems with update to 1.11.07.09 - 1/26/2008 2:31:39 AM
rajul
Status: offline
Hi hvta, great! I actually use 100% for the vertical camera delay as I like to do spins (upright, inverted, and KE) from a higher attitude. You'll find that with a lower setting, your flying attitude is limited. It's a matter of personal preference.
Mike Marks
RCU Moderator
