Rip n Bank -> RE: Sig P-51B gas+build thread (2/1/2008 3:37:07 AM)
quote:
ORIGINAL: jmohn Ed, I think it's just the angle of the photo and lighting because the spinner fits perfectly. It looks just like the real thing or as close as you can get for an off-the-shelf spinner. Here's another photo that shows it better. Jeff Hi Jeff, I have to agree with Ed on this one. Your last photo actually tends to support his point about excessive taper being evident on the cowl to match a "too small" diameter spinner. Especially if you look closely at the intersection of the cowl and the spinner where the lower prop blade is seen in your photo. The full scale Mustang, as well as my 60- and 150- size H9's P-51's, show a smooth, continuous parabolic arc transitioning from the spinner to the leading edge of the cowl (see pics below: red spinner = H9 60; yellow = H9 150). Granted, H9 has made numerous other compromises on these "sport-scale" warbirds, but they definitely got the "spinner-to-cowl" transition right! OK, the shrewd ones out there may point out that neither of my 'Stangs is shown with a factory-provided spinner. True, they are both Dave Brown spinners. The H9 60 didn't come with one (kudos to SIG) and the one provided with the 150-size is too flimsy to be anything but static only. That being said, the DESIGN of the cowls on both of these H9's tracks almost perfectly with a continuing parabolic curve from either the 3", or 5" aftermarket parabolic spinners, respectively. Don't get me wrong: I still think this is an excellent ARF, and H9 had better be paying attention to SIG and TF for lots of other reasons, only one of which is factory-provided flaps on a 60-size 'Stang, but, frankly, this is a rather noticeable, and disappointing, flaw... Rip
