NoFlaps -> RE: Sig P-51B gas+build thread (2/27/2008 6:57:30 PM)
Jmohn, Actually, I haven't...[&:] The plane should have by all accounts been finished a-long time ago, but I suppose this is the point that I admit I have OCD issues when it come to the little things and the fact that I got the invasion stripes wrong has been drining me crazy, so last night I pulled them off [>:], taking the star and bar with them . I tell you what: that industrial vinyl I used does not wnt to come off! Needless to say, the stars and bars didn't make it, so I'm going to order some Major decalss, or create my own to replace the two that lost the battle last night.. with the exception to that, I've done everything else except for putting the gear doors on. the plane is flight ready except for needing to either TAP out the factory FPE prop bolt, so that it can accept the spinner or getting a new bolt and then prop nut adapter. I guess I had better really inspect the balance of the spinner while I'm at it.[;)] BTW -The rear radiator door is cool to see operate and it's a neat visible indicator of where the carb position is prior to starting.
