NoFlaps
KY, USA Status: offline
FINALLY Maidened today. !!! Had several problems (self-induced) on Fridays' proposed test flight, wheels / struts were'nt aligned and tail wheel wasn't working properly, so tests were cancelled. Flight today was without struts, I used the factory gear that came with the air retracts, CG was a lil tricky as the the engine weights quite a bit and battery and all had to be moved all the way to the rear. a radio glitch ocurred immediately after I retracted the gear, so I put them back down, turned her around and was trimming it out as i made the down-wind leg, set up with 1/2 flaps and settled her in nicely for a landing. tailwheel is still a problem,, so i'll deal with that and the servo problem before the next flight (hopefully this week). The FPE flew the plane very nicely with a 16x8 prop, but i'd like to see it with a 16x10 or 15x10. Pics will be posted tomorrow.
_____________________________
Any landing you can walk away from is a good one.
