NebulaDDS
FL, USA Status: offline
When you say "covering material", I'm talking about using a something thin, like fiberglass.....not bent balsa strips. Would fiberglass not support itself? Basically, what I'm thinking is that the covering material would serve no structural purpose. It would merely be decorative (i.e. to make the plane look like an Extra 330L) and for aerodynamics. As for the central boom, I'm thinking that using a large carbon fiber tube with perhaps 1mm thick walls with a diameter of around 1.5" diameter would produce ample rigidity for the airframe, and it would weigh less than two-dozen stringers. In my "design", I have only three stringers present because I need them to handle two tasks; 1. to provide some support for the covering material between the ribs, and 2. to help keep the ribs from swiveling and/or tilting around the central boom. Neither of these put much force on the carbon fiber stringers. True, strength is not the same as stiffness, but they are closely related. Stiffness (a.k.a. "modulus of elasticity) is the amount of pressure that can be applied to a substance without it undergoing plastic deformation. Strength (a.k.a. "yield" defines the point where a substance begins to deform plastically. Hence, a material that has a higher modulus of elasticity is also going to have a higher yield strength. Now, you may be thinking of "absolute strength", which is the point where a substance actually breaks. In some substances (like glass), the absolute strength and the yield strength are the same. In others, like wood, the absolute strength is higher than the yield strength....meaning that wood can deform plastically before it actually breaks. But try to remember that where structures are concerned (like airframes), it is the material's yield strength that is important. Once an object deforms plastically, it is worthless to the structure...even if it hasn't broken apart. Where carbon fiber and wood are concerned, wood may (or may not) have a higher absolute strength, but carbon fiber's yield strength is higher than wood's. And again, it's the yield strength that's important. As for the expense.....I can handle that. And I agree with what you're saying. However, by having this discussion with you, I am learning a lot.
