CA, USA Status: offline
Thank you for the kind words, Richard.
I enjoy helping others in this hobby....goodness knows it's expensive enough as it is, and the parts prices are rather high. I get a kick out of fixing things, and beating the system out of a few bucks whenever I can, and I don't mind spreading some help around if I can. Besides....I have a new dial indicator and stand, and a new brass dead blow hammer to put into action....
....let the fun begin.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
NC, USA Status: online
quote:
ORIGINAL: Flyboy Dave
That attitude is exactly what makes rc such a great hobby. Modelers helping modelers.
quote:
ORIGINAL: vicman
Dave, Do you want the whole engine or just the crank?
The best thing for me, is to have the crankcase w/bearings, or bushings....and the crank like this:
Joined: 4/17/2005 From: goolwasa, AUSTRALIA Status: offline
quote:
ORIGINAL: vicman
Sheet, bar, coil, and wire are offered as cold rolled product. Plate is thicker and not available. I will not stray any further from the topic. If you require further definition feel free to pm me.
Got me there ,I was only thinking of the stuff I use to work with. By the way an old trade school instructor once told me a boilermaker \welder was a sheetmetal worker with his brains beaten out. That should set the cat amonst the pidgens. Cheers the pope
< Message edited by the pope -- 1/24/2008 7:33:58 AM >
FL, USA Status: offline
Just curious Dave, have you run across any new engines that don't have a 60 degree chamfer on the big end or a center drill on the small? So you can run the crank between centers.....
....not really....any engine turned like this could checked on centers, like on a lathe. I have seen some older engines that were not turned on the big end... just rough cast and drilled for the air passage.
quote:
ORIGINAL: craigpuckett
I will be sending Dave a very bent LA40 crankshaft as soon as I work off this evening....
....it hasn't arrived yet, Craig. Maybe monday.
....yep. I'll show exactly how it's done....no problem.
FBD.
TX, USA Status: offline
I may have one for you later today. I planted my P90 yesterday and took 5 minutes of pulling and wiggling to get the saito 120 out of the ground. Will know after I disassemble it. Edwin
Well Edwin....hopefully it's not bent....
....but if it is, it can probably be straightened.
....did you say the crank was stuck in the case ???
