fuel for OS37
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Century - Predator, Hawk IV, Falcon, Raven >> fuel for OS37
Page: [1]
Login
fuel for OS37 - 1/23/2008 1:07:12 PM
wak86
Status: offline
what is better fuel for this engine...better use castor fuel or synthetic fuel..which one is good.....any advices...how much % nitro ?
       Post #: 1
RE: fuel for OS37 - 1/23/2008 5:41:19 PM
syclic
Status: offline
A good heli fuel with all synthetic.
(in reply to wak86)
       Post #: 2
RE: fuel for OS37 - 1/25/2008 1:40:19 PM
wak86
Status: offline
how about castor...any disadvantages
< Message edited by wak86 -- 1/25/2008 1:41:45 PM >
(in reply to syclic)
       Post #: 3
RE: fuel for OS37 - 1/25/2008 5:53:16 PM
rowdog_14
Status: offline
I did my research before hand, but a lot of people told me not to use my omega 15% but it has the same mix as coolpower 15% only thing different is that omega has castor/ synthetic blend. I have used 30% heli before but for the few extra bucks to me it is not worth it, plus I am just a sport flyer and I do not need the extra power, but it does have more oil content in it. My omega can be used in 2 stroke runs great in 4-strokes and I will also be using it in my new tt .39 engine, because nobody can give me a logical answer into why not to use it. If you want to keep you heli clean then use coolpower % synthetic if you want a little bit more protection on your engine if it ever runs a little lean the go with Omega. Omega will make brown burnt spots on your engine, but I do not mind that because my rc toys are not for show. I have used coolpower before because the LHS was sold out of omega and I did not notice a difference other than it was a lot easier to clean my plane when I was done flying. This is just my opinion.
(in reply to wak86)
       Post #: 4
RE: fuel for OS37 - 1/25/2008 11:45:52 PM
syclic
Status: offline
The main reason why I do not recommend using any castor in the fuel, is because the same build up that you find outside the motor, also happens inside the motor (on the crown of the piston and sometimes inside the ring gap). This will eventually lead to erratic needle settings, as the build up on the crown of the piston, causes the volume inside the combustion chamber to decrease. In effect this increases the compression ratio which ultimately effects the timing.
The more fuel one burns per year the more noticeable this will be. As I burn anywhere from 20 to 40 gallons a year it is a significant consideration.
Years ago I would always add a bit of castor to protect the bearings from moisture contamination when stored. As most good fuels today have rust inhibitors I have even stopped doing that.
< Message edited by syclic -- 1/25/2008 11:47:03 PM >
(in reply to rowdog_14)
       Post #: 5
RE: fuel for OS37 - 1/26/2008 3:07:51 PM
wak86
Status: offline
is it the synthetic make engine fast demage..i mean the long life of engines will become short time
       Post #: 6
RE: fuel for OS37 - 5/5/2008 7:12:50 AM
evilhorse
Status: offline
synthetic fuel will kill your engine faster on a LEAN run, whereas synthetic/castor blend will save the engine for a short time.
_____________________________
Life is short, fly HARD
(in reply to wak86)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.691RCU1
