please help--AFPD can't find transmitter
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> please help--AFPD can't find transmitter
Page: [1]
Login
please help--AFPD can't find transmitter - 1/23/2008 3:47:03 PM
Max1
Status: offline
Is there any way to check to see if one has a bad cable? i have tried my system on 3 different pc's and it can't find the radio? thanks sammie
       Post #: 1
RE: please help--AFPD can't find transmitter - 1/24/2008 12:51:45 PM
rajul
Status: offline
Hi max, did it use to work before? What error message are getting from AFPD now?
Which addons and patch version did you install? Thanks
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to Max1)
       Post #: 2
RE: please help--AFPD can't find transmitter - 1/24/2008 1:49:54 PM
Max1
Status: offline
here is the error i get......thank you max
Click to see fullsize image.
Click for fullsize
(in reply to rajul)
       Post #: 3
RE: please help--AFPD can't find transmitter - 1/24/2008 1:53:33 PM
rajul
Status: offline
Hi Max, the pic's resolution is too low for me to make out the words. Could you write it down here? Thanks
Mike Marks
RCU Moderator
(in reply to Max1)
       Post #: 4
RE: please help--AFPD can't find transmitter - 1/24/2008 2:16:25 PM
Max1
Status: offline
Aerofly has located the USB interface cable but was unable to either find a transmitter connected to the USB interface or a joystick connected to the game port
(in reply to rajul)
       Post #: 5
RE: please help--AFPD can't find transmitter - 1/24/2008 2:19:48 PM
Max1
Status: offline
rajul yes it did work before
(in reply to Max1)
       Post #: 6
RE: please help--AFPD can't find transmitter - 1/24/2008 2:24:48 PM
rajul
Status: offline
Hi max, which transmitter are you using, and what type of adapter cable are you using? If you do not have any addons, then make sure that the patch you installed is version 1.8.0.25
Mike Marks
RCU Moderator
(in reply to Max1)
       Post #: 7
RE: please help--AFPD can't find transmitter - 1/24/2008 2:35:15 PM
Max1
Status: offline
hi my radio is a futaba FP-T7UAP that i have always used with my AFPD and i do have the version 1.8.0.25 ......can i get a new adapter cable ? i think the one i have and have been using on this radio is from a G2 that i use to have but sold after i get my AFPD. everything was working great till last week....we have installed it on 2 other pc's and have the same problem as this pc....thanks for all your help........max
(in reply to rajul)
       Post #: 8
RE: please help--AFPD can't find transmitter - 1/24/2008 3:12:44 PM
rajul
Status: offline
Hi max, did you set your radio to PPM mode?
Mike Marks
RCU Moderator
(in reply to Max1)
       Post #: 9
RE: please help--AFPD can't find transmitter - 1/24/2008 3:27:22 PM
Max1
Status: offline
Hi rajul
yes it all worked great till a week ago. i did get a new Nvidia 8800 GTX OC 768MB video card...every thing works great expect my AFPD?
(in reply to rajul)
       Post #: 10
RE: please help--AFPD can't find transmitter - 1/24/2008 3:35:08 PM
rajul
Status: offline
Hi Max, it seems like your G2 adapter cable is faulty. i would recommend that you get a high quality adapter from here http://www.ikarus-modellbau.de/onlineshop/usa/index.php?sid=256db4a5b1cc35057882ec53632398d0&cl=details&cnid=217&anid=2c4446c15cd8ca088.63839801 or here https://www.fxaeromodels.com//product_info.php?cPath=141&products_id=1658
Mike Marks
RCU Moderator
(in reply to Max1)
       Post #: 11
RE: please help--AFPD can't find transmitter - 1/24/2008 3:39:33 PM
rajul
Status: offline
Hi max, also make sure you installed the latest driver for your new video card
Mike Marks
RCU Moderator
(in reply to rajul)
       Post #: 12
RE: please help--AFPD can't find transmitter - 1/24/2008 4:01:45 PM
Max1
Status: offline
thank you for all your help......have a great week.....max
(in reply to rajul)
       Post #: 13
RE: please help--AFPD can't find transmitter - 1/24/2008 4:05:39 PM
rajul
Status: offline
Hi max, I just realized that the FPT7UAP is an old Futaba radio. If it is using a round DIN connector behind it, then the correct adapter is this http://www.ikarus-modellbau.de/onlineshop/usa/index.php?sid=b46162d346909e22688126400cf8a731&cl=details&cnid=217&anid=4314
Mike Marks
RCU Moderator
(in reply to Max1)
       Post #: 14
RE: please help--AFPD can't find transmitter - 1/25/2008 11:41:37 AM
Max1
Status: offline
rajul thank you for all your help.......have a great weekend......max
(in reply to rajul)
       Post #: 15
RE: please help--AFPD can't find transmitter - 1/28/2008 4:30:05 PM
